hdfury 4k integral άριστο
thor
Διαθέσιμο!
Main Specifications
  • 2x Input / 2x Output Splitter (HDMI2.0a/HDMI1.4/DVI1.0 compatible)
    4K60 4:4:4 600MHz 18Gbps Pass through
    4K60 4:4:4 600MHz 18Gbps > 4K60 4:2:0 300MHz 10.2Gbps conversion
    HDCP Doctor (HDCP Workaround solution to any HDCP error)
    HDCP 2.2 > HDCP 1.4 conversion
    HDCP 1.4 > HDCP 2.2 conversion
    HDCP x.x > HDCP x.x conversion
    Dual HDMI2.0a & HDMI 1.4 combined
    Dual HDCP 1.4 & HDCP 2.2 combined
    CEC Support: For inter-device control between both inputs and the primary output (TOP) HDMI channel.
    CEC command: USB configuration for automation, trigger via events, push button or via IR/Bluetooth
    External Audio Replacing: input external sound or switch sound between input
    Audio Extracting: Audio De-Embedder of Optical & Analog L/R
    Advanced EDID management via USB, IR or Bluetooth APP
    Improved EDID Management solution with either a Selected EDID bank, Custom uploaded EDID, Self generated Automix EDID or a Fixed basic EDID.
    Sniff EDID from connected sink devices, Save, Edit, Load any custom EDID table at any time.
    Select and pick any EDID of your choice from a preloaded list of EDID tables, it loads and reset HPD to present your chosen one automatically.
    AutoMix EDID feature will create a custom EDID by mixing both sink EDID connected to the splitter output ports.
    Some EDID flags can be forced in Automix such as: Stereo/5.1/Full/YCbCr/BT2020/HDR/DV/3D.
    HDR & InfoFrame Live Injector.
    HDMI Booster/Extender: Capable of extending 1080p resolution up to 15m. in and 15m. out (30m. total for 1080p), UHD resolution up to 10m.
    HDMI Doctor: Solves most HDMI integration issues such as HDCP, EDID, HPD, and audio breakout.
    HDMI Equalevel: Precise signal equalization towards both input and output signals perfectly delivers the best possible picture quality.
    Hot-Plug control: Force the input device to always see an active connection.
    Licensing: Fully licensed and compatible with all HDMI and HDCP technologies.
    Deep Color Support
    Dolby Vision Support
    xvYCC Color Support
    Flexible/Portable/Plug’n Play
    3D Ready: Capability to pass 3D stereoscopic signal formats.
    Just like any recent HDfury hardware, it comes with USB upgradable firmware that allow you to unleash furious features.
thor
Διαθέσιμο!
δεκτή και ανταλλαγή με κάτι που να με ενδιαφέρει
thor
Διαθέσιμο!
thor
120€
opanamas
