Heed Audio
H Heed Audio είναι Ουγγρική εταιρεία πού σχεδιάζει καί κατασκευάζει εξαιρετικά προϊόντα στίς "παρυφές" τού ΠΡΑΓΜΑΤΙΚΟΥ Hi End , μέ τιμές LOW !!!!
HEED AUDIO OBELISK Si
http://www.heedaudio.com/en/obelisk_reviews.html
HEED AUDIO CANAMP
"The CanAmp is a two-stage amplifier. While the first - voltage gain - stage is based on an integrated circuit of the highest audio pedigree, the second - power gain - stage is a single-ended, pure Class-A amplifier. It enables the CanAmp to drive virtually any headphones from 8 ohms up to 600 ohms. As its output power (at 8 ohm) is nearly 1W, the CanAmp could drive even a high-sensitivity loudspeaker!
The unit has no internal wiring, and the signal path is kept to a minimum on its PCB.
Its high-quality, 1 dB-tolerance Blue Alps volume pot goes through a further selection process during manufacturing to achieve an even tighter, 0.5 dB tolerance."
HEED AUDIO Quasar Phono Stage
with separate power supply
- dual mono configuration from power supply
- 'Low' and 'High" outputs can be used together
- MM input sensitivity: 3 mV
- MC input sensitivity: 0.1 / 0.22 / 0.6 mV
- MC input impedance: 100 / 220 / 470 / 47k Ohms
- "Low Out"output: 220 mV / 100 Ohm
- "High Out" output: 775 mV / 22 Ohm
http://www.heedaudio.hu/en/documents/quasarimagereview.PDF
HEED AUDIO ORBIT 2
Turntable Power Supply
Heed Audio manufactures extremely high-value entry-level high-end solid-state electronics. Preamplifiers, integrated amplifiers, monoblock amplifiers, as well as add-on components like headphone amplifiers, phono stages and DAC's that provide maximum performance for the money. Heed products have been highly praised by prestigious hi-fi magazines (Hi-Fi Choice, Hi-Fi World, What Hi-Fi, Image Hi-Fi, Diapason, Prestige Audio&Video, Le Monde de la Musique, to name just a few), and won various coveted Awards (Diapason D'Or, CHOC, Image, etc.)
xkaragi
