Hegel νέα κόλπα...
deleted user 10898
FAIRFIELD, IOWA, March 17, 2011 – HEGEL Music Systems, world-renowned for high-performance audio electronics, unveils the HD2 and HD20 DACs, featuring what may be the world’s most advanced jitter reduction circuitry.
Jitter – What Really Matters
When assessing DAC performance, people often ask: “Does it run in asynchronous mode?”, or “What DAC chip are you using?”, or Does it run native 88.2 kHz?”
According to Bent Holter, founder and chief designer of HEGEL, these discussions subordinate the real issue: jitter reduction. Says Holter: “Jitter is what matters. A DAC chip can only work with what it’s given. If the data-stream is not properly synchronized between the sender and the receiver, even the most expensive DAC chip will fail to produce music.”
Holter continued: “Unfortunately, the common solution to jitter is to run DAC chips in so-called ‘asynchronous mode’. The problem is that, in most cases, it doesn’t work. Often, DAC’s in ‘asynchronous mode’ actually INCREASE jitter. Measurements prove this. Hegel’s approach is very different.
HEGEL DAC’s utilize a proprietary re-clocking circuit, with highly precise buffers and an advanced crystal clock developed by HEGEL engineers. This circuit HALTS the data stream, re-builds it, and feeds it in near-perfect rhythm to the HEGEL DAC chip.”
Holter further observes: “This not just a design philosophy. The results can be proven and experienced. Distortion is measurably lower on HEGEL DAC’s, due to attention placed upon jitter-reduction.
The finest test instrument, the human ear, is unerring. With reduced jitter, listeners immediately notice the absence of distortion and greater tonal purity. But…the most striking result of jitter-reduction is: Enhanced Bass. With HEGEL DAC’s, listeners are surprised to hear another layer of clean, powerful bass emerging from pure silence”.
http://www.avguide.com/article/two-new-dacs-hegel-music-systems-feature-jitter-reduction
deleted user 10898
HEGEL HD2 – USB DAC
Arriving to US shores this week, the HD2 is a USB DAC, with the highest quality re-clocking circuit available.
The HD2 provides an SPDIF output, so it can be used as a pure re-clocking device and/or a 24/96 kHz US interface for an existing DAC.
HD2 up-samples incoming signals to 24/192.
US Retail Price: $350.
HEGEL HD2 USB DAC front panelHEGEL HD2 USB DAC back panel
HD20 DAC
Arriving in April: HEGEL’s new HD20 DAC.
A major step-up from last year’s HD10, the HD20 features a vastly improved analog stage, with less distortion and a lower noise floor.
HD20 offers both balanced and single-ended outputs, and multiple digital inputs (COAX1 input provides impedance correction). Remote control supports both PC and MAC functionality. LED display is dimmable.
HD20 supports 24/192 on SPIF inputs, and 24/96 on USB inputs.
As with HD2, the HD20 utilizes a proprietary re-clocking circuitry, for extremely low jitter measurements. Distortion measurements are among the best recorded for any DAC yet produced.
US Retail Price: $2000
Απάντηση: Hegel νέα κόλπα...
αν και το λέει ανάποδα, έχει κάποιο δίκιο, από άποψη ψυχοακουστικής όμως.
το μειωμένο τζίτερ είναι άμεσα αντιληπτό χονδρικά ως μειωμένα πρίμα. Βέβαια, χωρίς να "λείπουν" πρίμα, φεύγει ένα "πέπλο" υψίσυχνου θορύβου που προστίθεται στα υπάρχοντα πρίμα της μουσικής. Αυτό είναι ο θόρυβος. Στα μπάσα, κάτι ανάλογο δεν υφίσταται.
ΙΜΗΟ
Eleni Sousani
