Hegel H200 Integrated Amplifier
Hegel H200, ολοκληρωμένος, σε άψογη κατασταση, ασημένιος, στα 1500 ευρώ.
Extremely powerful H200 High-End Integrated Amplifier, 2x200W in 8 ohms, 2x350W in 4 ohms. With its powerful 2x200 watt and a dual mono power supply it is much more dynamic and powerful than the H100 or H70. The H200 fills the gap between the integrated amplifier H100 and the combination of the pre amplifier P4AMK2 + H20 power amplifier. A new feature of the H200 is the Home Theatre input, allowing you to combine it with an external surround sound system. The H200 has a relay switched input source selector and can be connected to different types of music sources. A display shows the selected input source and volume setting. The integrated amplifier has a new digitally controlled active preamp stage and the new improved SoundEngine amplifier modules. It has got both balanced and unbalanced inputs.
The idea behind the H200 project was to design a new generation of amplifiers based on the new and improved SoundEngine amplifier technology from the H4A mk2 power amplifiers, combined with a completely new digitally controlled active preamp stage. The main goal was to keep the powerful and dynamic presentation of the H20 + H4A mk2 and combine it with a very transparent preamp stage. The sound has got powerful dynamic bass, a high resolution soundstage and a smooth, warm and detailed sound. The reduction of dynamic distortion all over the audible frequency range together with complete elimination of "transistor sound" makes the H200 sound smooth and transparent without losing any details. The H200 plays dynamic, pure and powerful.
Technical Details
Output power: 200W + 200W in 8 ohms, 350W + 350W in 4 ohms
Volume, Input source and mute controlled by Hegel RC2 remote
Inputs: CD (RCA), Aux (RCA) and balanced (XLR)
Home Theatre input: maximum level power amp input (RCA)
2 pcs Pre Out (RCA), 1 pcs Recording output (RCA)
Speaker outputs: Two pairs of heavy duty gold plated terminals
Input impedance: Balanced 50kohm, unbalanced 11kohm
Frequency response: Less than +/- 0.2 dB deviation 20Hz-20kHz
Phase response: Less than 2 degrees deviation 20Hz- 20kHz
Signal to noise ratio: More than 100dB
Crosstalk: Less than -100dB
Distortion: Less than 0.006 % at 100W i 8 ohm
Intermodulation: Less than 0.01 % (19kHz + 20kHz)
Damping factor: More than 1000
Power Supply: 1000VA dual mono, 90 000uF capacitors
Output stage: 20 pcs 15A 150W high speed bipolar transistors
Power consumption: 60W in standby switched on
Dimensions/weight: 12cm x 43cm x 38cm (HxWxD), weight 25kg
Dimensions/weight US: 4,7" x 17" x 15" (HxBxD), weight 55 lbs
Up μείωση τιμής στα 1300€. που είναι πια η τελική για έναν ενισχυτή όπως αυτός. Υπάρχει και τηλεχειριστήριο.Ειλικρινα ευκαιρία για όποιον θελήσει να τον αγορασή.
Τι άλλο να πω ρε παιδιά, καθαρόαιμος μουσικα Hegel , 200watt στα 8 ohms, σηκώνει τα πάντα.
Επικοινωνία με pm. Ευχαριστώ
Παρακαλώ πολύ να κλείσει,
καλές ακροάσεις στο φίλο Κώστα.
Ευχαριστώ το Avsite.
akalavo
