Hegel H360
Πωλείται o ολοκληρωμένος ενισχυτής Η360 σε άριστη κατάσταση και λίγες ώρες λειτουργίες. Αγορασμένος το 2017.
Τιμή 2900 Ευρώ για γρήγορη πώληση! Δεν θα συζητηθεί περίπτωση ανταλλαγής.
Η ποιότητα του και το ηχητικό αποτέλεσμα είναι αδιαμφισβήτητa.
Περιγραφή:
Hegel H360 is a giant among integrated amplifiers. With 250 watts per channel into 8 ohms and a damping factor of more than 4000, it will control virtually any loudspeaker on the market.
Thanks to the patented SoundEngine technology, this beast of an amplifier combines power, dynamics, finesse and musicality like no other integrated amp on the market. The connectivity is more of a bonus… There are balanced and unbalanced analog inputs. There is a Home Theatre bypass. There are optical and coaxial digital inputs, as well as a USB input for any signal up to DSD128… And, yes – it is also a streamer. Need we say more?
Χαρακτηριστικά:
Power output spk: 250 Watt/pc into 8 Ohms, 420 Watt/pc into 4 Ohms
Analog inputs: 1 balanced (XLR), 1 unbalanced (RCA), 1 home theatre
Analog outputs: 1 fixed line level (RCA), 1 variable line level (RCA)
Digital inputs: 1 coaxial, 3 optical, 1 USB, 1 ethernet (RJ45)
Digital outputs: 1 coaxial (from digital inputs only)
Control input: 3,5 mm IR-Jack (rear)
Frequency response: 5Hz-180kHz
Signal-to-noise ratio: More than 100dB
Crosstalk: Less than -100dB
Damping factor: More than 4000 (main power output stage)
Dimensions: 12cm (15cm w/feet) x 43cm x 43cm (HxWxD)
Weight: 20,5kg (net), 24kg (shipping)
Dimensions US: 4.72” (5.9” w/feet) x 16.93” x 16.93” (HxBxD)
DAMBO
