Hegel HD30 DAC
Chameleon Audio
Σε άριστη κατάσταση με τα κουτια του.
Τιμη 2250 euro
Chameleon Audio
Ηλιουπόλεως 102, Δάφνη
Επικοινωνία: 213 027 7796 / 6972288374
https://www.chameleonaudio.gr
Technical Details
DAC resolution:
Dual mono 32 bit/192 kHz multilevel sigma-delta DAC
Line output: 2.6 V RMS
Digital inputs: 1 x coaxial, 3 x optical, 1 x USB, 1 x Ethernet, 1 x BNC, 1 x AES/EBU
Analog outputs: 1 x fixed line level (RCA), 1 x fixed line level (Balanced XLR)
Distortion: Typical 0.0005%
Frequency response: 0 Hz - 50 kHz
Noise floor: Typically -150 dB
Power supply: Separate torodial transformers for analog/digital 54,000 μF capacitors
Output impedance: 22 ohms unbalanced and 44 ohms balanced
Control input: 1 x IR-direct mini-jack
Finish: Black and Silver
Dimensions/weight: 8 cm (10 cm w/feet) x 43 cm x 31 cm (HxWxD), 6,5 kg
Dimensions/weight US: 3.14" (3.93" w/feet) x 16.93" x 12.20" (HxBxD), 14.3lbs
"ΠΡΟΣΦΟΡΑ"
Στην τιμη μπορουν να γινουν 10 ατοκες με πιστωτικη καρτα
opanamas
