High Definition DV Camera with 5x Optical Zoom
Πωλείται καινουργια στο κουτι της η παρακατω καμερα HD
High Definition 720p Διαβαστε χαρακτηριστικά.
Δεν εχει ανοιχτει ποτε.
Τιμή 250 euro.
Χαρακτηριστικά.
Manufacturer Specifications
* Primary Function: Budget Friendly HD Camcorder. The DV camera for the average guy.
* LCD screen: 3 Inch TFT LCD
* Lens:
Wide - F/3.2, f=6.26mm
Tele - F/6.8, f=30.75mm
* Focus range:
Normal - 50cm ~ Inf.
Macro - Wide (20 ~ 45), Tele (5 ~ 45)
* Shutter: 1/2 ~ 1/2000 Sec
* Sensor Sensitivity: Auto
* Imaging Sensor: 1/2.5" CMOS 5.0MP
* Storage media:
- Internal: 128MB
- External: SD Card up to 4GB (Support for SDHC Mode 6)
* Digital Video Camera
- File Type: MOV (H.264)
- Resolution: 1280x720 @ 30 FPS (720p HD), 720x480 @ 30 FPS (WVGA), 640x480 @ 30 FPS (VGA)
- Video Quality (compression): Fine, Normal
- Optical Zoom: 5x
- Digital Zoom: 20x
- Video Settings: Effects, White Balance, Stabilizer ON/OFF, Night Mode, Macro Mode
- LED Highlight: ON / OFF
- EV: 4 steps (+2 to -2)
* Digital Picture Camera
- File Type: JPEG
- Resolution: 12MP (interpolation), 5MP (native), 3MP
- Image Quality (compression): Fine, Normal
- Optical Zoom: 5x
- Digital Zoom: 20x
- Flash: ON / OFF / Auto
- Picture Settings: Color Effects, White Balance, Night Mode
- Snapshot Options: Macro Mode, Self Timer, Image Stabilizer
- Banding: 50Hz, 60Hz
* Power supply: Rechargeable Li-ion battery
* Typical Battery Life: up to 80 minutes of video recording
* PC interface: USB 2.0
* AV OUT: YES
* HDMI OUT: YES
* TV Output: PAL / NTSC / Selectable
* OSD Languages: English, German, French, Italian, Spanish, Portuguese, Dutch, Korean, Turkish, Japanese, Russian, Arabic, Traditional Chinese, Simplified Chinese
* Computer Required: NO
* Software specs for included photo editing software are as follows:
- Operating System: Windows 2000 / XP / Vista / Windows7
- CPU: Pentium 4, 2.8GHz or equivalent
- RAM: 512 MB minimum
* Dimensions: 129mm x 57mm x 70mm (L x W x H)
* Certification: CE, FCC
* Manufacturer Ref: D75C8CAB78AC
* Catalog Ref: Video camcorder with high mega pixel imaging sensor
Product Notes
* White LED lights for filming in darker conditions
* 270 Deg Rotating Screen
* Budget Friendly HD Camcorder. The DV camera for the average guy.
* Auto power off options - 1min, 5min, never.
* When using DIS mode with WVGA setting you can achieve 60FPS videos
Package Contents
* Camera Bag with strap
* HDMI Cable
* USB Cable
* AV Cable (2.5mm to RCA)
* Rechargeable Li-ion battery - NP60 (3.6V 1100mAh)
* Battery Charger and cable (100-240V, 50/60HZ)
* Manual - English
* Software CD
2130309726
6909994010
Απάντηση: High Definition DV Camera with 5x Optical Zoom
Ειναι αγορα απο Hong-Kong δέν ειναι επονυμης μαρκας.
Πολυ αξιοπιστες αλλα δεν ειναι επονυμες.
koskef
