Απάντηση: Home Theater Projector Shootout Eight 1080p Projectors under $1500
Μην πιστεύεται τίποτα από αυτά, είναι λάθος κάθε ένας για δικούς του
λόγους γράφει οτιδήποτε, πχ.
Ξέρω τον Optoma HD20 ο οποίος έχει 1700 lumens, και όντως είναι υπερφωτεινός!
<Maximum Light Output
Sometimes you just need to blast an image onto the wall, and things like contrast and color accuracy become less important. In these circumstances, what is important is maximum light output. While the projectors below are ranked numerically, the Epson Home Cinema 8350 deserves special mention for excellent color accuracy in its Dynamic mode, a feat which no other projector in the shootout can match.
Ωραια τεστακια ειναι αυτα....
Απλα δεν βαζουν λεπτομεριες στο πως και τι....για διαφορους λογους....
Παντως ο optoma 20 που λεει ο Λιακος,απο οτι ειδα σε αλλα τεστ,καπου εκει ειναι η φωτεινοτητα του ρυθμισμενος ωστε να αποδιδει καλη εικονα και ισοροποιμενη....
Κωστα δεν μιλαει για ρυθμισμενος ,λεει μαξιμουμ φωτεινοτητα.Κι εμενα μου φαινεται καπως χαμηλο το νουμερο.Παντως οι προβολεις υπαρχουν στην ελληνικη αγορα απλα τα μοντελα ονομαζονται διαφορετικα πχ.Ο Επσον ειναι ο 3600.
The dissapointment comes from the Optoma claim of 1700 lumens. Now, most companies tend to overstate their brightness, and often significantly. That said, let's say that Optoma may have gotten a bit carried away, since it measured almost 40% less than their claim. (15% - 25% isn't that unusual, and it's rather uncommon to find a projector that beats its marketing claim).
Ultimately, though, we measured an impressive 701 lumens in our calibrated Cinema mode (User mode). Bright mode, measured 996 lumens (with just minor adjustments). Both numbers are post calibration measurements. Actually, using out of the box settings, Cinema mode was dimmer, though insignificantly, at 695 lumens
In truth, one can make the projector brighter. I ended up increasing contrast from a recommended setting of 44 to 54, which definitely put an extra 100+ lumens on the screen, but was definitely starting to crush some near-white highlights. Still, this worked well when fighting a bit too much ambient light.
These were the measurements for all modes, Pre-calibration. Shown along with the lumens are the color temperature measurements for white (100 IRE):
Ακόμα και με μείον 25% η φωτεινότητα θα ήταν 1250 lumens, πιστεύω δύσκολα θα έχουμε τόση μείωση, όση λέει το ''τέστ''
όμως δεν κατέχω τα τεχνικά, και δεν μπορώ να είμαι και σίγουρος!!!
Και μπορω να πω οτι ειναι παρα πολυ εως πολυ-πολυ κοντα τα ρυθμιστικα για καλη ρυθμιση και ισοροποιμενη εικονα σε ολα...οπως τα δινουν.
Στις περισοτερες περιπτωσεις χανεις ενα 30-40% φωτεινοτητας για καλο αποτελεσμα απο αυτα που δινουν οι εταιριες..
Εαν δεν το κανεις ο ιδιος δεν μπορεις να εισαι σιγουρος ποτε...
Στον πανασονικ ειναι 100% μεσα σε φωτεινοτητες οι μαγκες......και μεση ζουμ παιζω και φωτεινοτητες ιδιες εχω...(ειχα..μιας και εχω γραψει καμια 500αρια)
