Κώστας Φ.
Specifications:
Frequency Response: 25 Hz to 25k Hz
Sensitivity: 90 dB
Impedance: 6 ohms, 3.8 ohms Minimum
Power Requirement: 10 W Minimum, 200 W Maximum
Woofer: 8", 2nd Generation Aluminum S.V.F. Woofer x 2
Midrange: 6-1/2", 2nd Generation Hard Surround Carbon Fiber Driver with S.V.F., M.F.D.S. & R.P.R.D.
Tweeter: 1” Silk Dome
Crossover: 1st Order @ 150 Hz & 3k Hz
Weight: Upper Cabinet 21 Lbs (Unpacked)
Lower Cabinet 65 Lbs (Unpacked)
Special Features:
1. With S.V.F. and M.D.S., the newly designed 2nd generation midrange driver is built with hard surround to further improve the performance in terms of speed and clarity and Rear Pressure Reduce Device (R.P.R.D.) to minimize the rear pressure reflection influence.
2. Matching drivers with cabinets perfectly instead of music killing capacitors, the new crossover design achieves the extreme phase accuracy. No low frequency cut on midrange, and all drivers are in 1st order arrangements.
3. 2nd generation aluminum woofers for lower base extension to 25Hz.
4. Adjustable tilt angle for top cabinet in the effort of finding the sweet spot (with laser pointer).
5. Top cabinet 3 point placement with bronze bearing spheres for easy installation.
6. Room Reactance Control for adjusting treble in different room conditions.
Price: $7000 per pair
"The Hyperion 968s are truly a reference quality speaker in all the most important facets of performance, fit, finish and design. They have marveled me in the most undeniable way with their uncompromising musicality, clarity and faithfulness. I have the gut feeling that it will be quite some time before I hear anything at this price point that will surpass them. If any one is in the market for a speaker below $20k (and possibly even higher) I highly recommend taking the time to listen and/or audition these speakers before possibly coming too heavily out of one’s pocket. I have a feeling they just might be very happily impressed and surprised at their price to performance ratio.
Bravo, Hyperion, as you have melded together Earth and Heaven to produce a truly Titanic speaker."
Full Review: Stereotimes.com
