iJokes...
Gebreselassie
Μαύρος!
Q: Why did Steve Jobs live his last moments in regret?
A: They say your life flashes before your eyes just before you die. Unfortunately for Steve Jobs, his iPhone 4S didn't have a Flash player installed!
:204::204::204:
Απάντηση: iJokes...
Μια χαρά flash έχει το iphone αρκεί να αγοράσεις ενα browser που να το υποστηρίζει όπως το skyfire. Εγώ βλέπω όλα τα ματς του γαύρου από το Ipad!
Gebreselassie
Μαύρος!
Q: Why is Apple offering a free case for all iPhone 4 buyers?
A: It doesn't help with reception, but protects the iPhone when you throw it against the wall after dropping a call!
:135::143:
Gebreselassie
Μαύρος!
Problems continue for this new iPhone 4s. To give you an idea of how bad are now, flight attendants are now telling passengers, 'Eh, don't shut 'em off after take off. You' re fine, you' re not going to get any calls anyway.
:405::405:
Απάντηση: iJokes...
Βλέπω με μεγάλη χαρά πως οι φίλοι διαχειριστές/συντονιστές του avsite βοηθάνε με τον τρόπο τους τη νέα κατηγορία από τις πρωτες κιόλας μέρες της λειτουργίας της!
Special Thanks!:204:
...καλά!!! Ειναι απίστευτο τι έχουνε βγάλλει!!!!:116:
(οχι οτι δεν ειμαι fan βεβαια!!), αλλά μιλάμε για πολύ γέλιο!!!!
Gebreselassie
Μαύρος!
All over the country today there were huge lines at Apple stores for the iPhone — not to buy them, to return them. Apparently, Apple is addressing problems with the iPhone. For now on, if you buy an iPhone, they throw in a Blackberry so you can make a call.
:114::114:
Gianni Tab
