iQube V5 portable Amplifier
m1ts0s
News poster
The iQube V5 Portable Headphone Amp & DSD DAC has a redeveloped famous class D output stage. It is a vast improvement over the iQube V3 with this reengineered output stage capable of driving even the most difficult headphones like the Sennheiser HD800. Qables was awarded as best in class and best in transparency many years in a row but they felt it was time to redevelop the iQube’s famous class D output stage. Bruno Putzeys and Bart van der Laan have surpassed themselves with this design. Bart has developed a full new iQube with many changes including a four layer medical grade type PC board, New class D output stages, a New stronger, more powerful, power supply based on a Lithium Ion cell with double the play time, and a digital controlled charging stage, a Full new digital section capable of any signal you can think of including DSD single dual rate DoP, a Floored noise level, a Full new digital controlled user interface with embedded software and coloured LED lighting. The casing design of the iQube V5 is the only thing that will remain the same but we did succeed in making it even lighter.
THD+n
200mV output (typ) 0.0045%, max output 0.025%
Frequency response
200mV into a 16 ohm load: Analogue input 5 – 50kHz (-1dB)
Power
160mW_16 ohm, 80mW_32 ohm, 12mW_200 ohm
Zout
<0.1 ohm @ f<5kHz, <1,5 ohm @ 20kHz
Output noise
7uV (unweighted)
DAC type
CS4392, 24 bit delta sigma, 114dB dynamic range
USB PCM audio
24 bit 44.1/48/88.2/96/176.4/192 kHz asynchronous
Supported Signals
DSD single (DSD64) and dual Rate (DSD128) over DoP (0x05/0xFA) and dCS (0xAA)
Analogue input
70hr playtime
Digital input
40hr playtime
€625
http://www.qables.com/shop/iqube/iqube-v5-portable-amplifier
  • rose.athens
Christos Kourmouzoglou
