Jamo AVR-693/AVR-793/DVD-593 DVD player
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Receivers και dvd player από την jamo.
ΑVR-693
6.1 channel 6 x 120w (6 ohms)
AVR-793 7.1 channel 7 x 135w (6 ohms)
toroidal transformers and high-grade capacitors (AVR-693: 40,000 µF, AVR-793: 60,000 µF)
high quality banana-plug
processing: Dolby Digital EX, Dolby Pro Logic IIX, DTS-ES (Discrete/Matrix 6.1)...
192kHz/24-bit DACs
AVR-793 high-bandwidth component video inputs and outputs and also sports 3 optical and 3 coaxial digital inputs (the AVR-693 has 2 optical/2coaxial) plus a 7.1 multi channel input for SACD/DVD-Audio sources (5.1 channel input in the AVR-693)
digital inputs on the front panel - AVR-693 optical , AVR-793 optical and coaxial
Jamo DVD-593 DVD player
plays CDs ,CD-R/RW ,DVD-R/RW,DVD+R/RWs.
DivX compatible
Component video output and progressive scan
outputs : composite video, S-Video, RGB Scart (European models only) component video.
Κώστας Φ.
Ενδιαφέροντα χαρακτηριστικά...Θα καταφέρει άραγε να χτυπήσει τις υπερδυνάμεις του χώρου (Yamaha, Marantz κοκ)??
proteusjohn
