Nick Arvanitakis
Audio Pro
Portable loudspeaker and DAB+/FM radio in one: the model has five memory buttons for radio stations so your favourites are always available at the touch of a button. You can also use the Tuner with your smartphone and other BT source devices as it also works as a Bluetooth® loudspeaker. Another practical highlight is the hands-free function for phone calls. It can be used anywhere thanks to an integrated lithium-ion battery (3,000mAh) - its robust housing keeps it safe when you're out and about.
Features
- Fantastic sound experience
- Five programmable radio station buttons
- Hands-free telephone function
- DAB+/FM radio
- Bluetooth® loudspeaker
- Robust body
- Connects to smartphone and other BT source devices
- Two integrated active bass radiators
- Bluetooth® 4.1
- Compatibility: A2DP V1.3; AVRCP V1.5; HFP V1.6; HSP V1.2
- Signal converter: 2 x 40mm
- Output: 2 x 7.5W
- Lithium-ion battery (3,000mAh, charge time up to 2.5 hrs.)
Aναμένεται εναγωνίως με τιμή πώλησης 99 ευρώ.
