Jean Marie Reynaud
Γάλλος κατασκευαστής ηχείων:
Established in 1967, the Jean-Marie Reynaud company was from the start animated by the passion of a man for state-of-the art musical reproduction.
Initially very small, the company gradually built up increasingly performing production and research facilities.
We now have at our disposal a 2000 m2 production and storage plant, which places us among the leading French companies working in the field of high-end audio.
A large anechoic room allows us to design, to develop and to produce extremely sophisticated, continuously enhanced products.
Our speakers are made from the very best components and benefit from the latest technical breakthroughs of our laboratory.
Yet, we strive to propose them at a very reasonnable price regarding their excellence, their outstanding construction and soul-moving performance.
Renowed and praised in the specialized press in France, our loudspeakers systems are now present in several countries.
Arpeggione
TECHNICAL CHARACTERISTICS
Power handling capacity 70 Watts
Repetitive peak power 135 Watts
Impedance 4 ohms
Frequency response 45.22000 Hz
Sensitivity 89dB/W/M
Distorsion less than 0.7% (level 84 dB)
Sound pressure level (SPL) 109 dB
Dimensions H 84" L 20" P 27"
Weight 18 Kgs (with sand)
Finish Cherry stained aniegre veneer
Connection Mono and Bi-Wiring
Evolution 3 Mk2
ELECTROACOUSTIC PERFORMANCES
Power handling capacity 90 Watts
90 Watts 270 Watts
Impedance 4 ohms ( minimale 3.6 ohms)
Frequency response 35.20.000 Hz
Sensitivity 88 dB/W/M
Distorsion less than 1% (84 dB)
Nominal SPL 108 dB
Dimensions H.42" L.8" D.12" (with spikes)
Finish Stained aniegre veneer on medite material rounded edges in solid wood
Connectors Mono and Bi-wiring
Weight 28 kg
Περισσότερα εδώ:
http://www.jm-reynaud.com/jmr_us/produits.html
Johnny, αυτός ο τύπος, μάλλον θα ακούει από B&W. :mrgreen:
Τι γίνεται βρε παιδί μου ...στερέψανε οι ιδέες. Το ένα ηχείο είναι η μέτρια σχεδιαστική αντιγραφή του 801 Matrix και το ψηλόλιγνο είναι η κακή αντιγραφή του 803 Nautilus.
Φυσικά, δεν μπορώ να έχω άποψη για τον ήχο τους, αφού ποτέ δεν είχα την ευκαιρία να τα ακούσω. Είναι και η πρώτη φορά που ακούω το όνομα αυτής της εταιρίας.
Gianni Tab
