Kenwood KA-501+KT-615
Ev 8848
Προς πώληση σέ άριστη κατάσταση σάν σετ.
Τιμή πώλησης 380 ευρώ.
Για άμεση επικοινωνία τηλ 6974273622
Specifications
Power output: 65 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.03%
Damping factor: 60
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 86dB (MM), 105dB (line)
Output: 200mV (line), 30mV (DIN)
Dimensions: 440 x 153 x 407mm
Weight: 10.7kg
Specifications
Type: Mono/Stereo Tuner
Tuning Bands: FM, MW
Tuning Scale: Analogue
FM Tuning Range: 88 to 108 MHz
MW Tuning Range: 520 to 1620 kHz
Sensitivity: 0.9uV (FM), 13uV (MW)
Signal to Noise Ratio: 67dB (FM), 50dB (MW)
Distortion: 0.35% (FM)
Selectivity: 74dB (FM)
Frequency response: 30Hz to 15kHz (FM)
Dimensions: 440 x 153 x 402mm
Weight: 7.2kg
mrkgeo
