Kenwood KSC-SW10 & SW50 active subwoofers
Kenwood KSC-SW10 active subwoofer
The Kenwood KSC-SW10 active subwoofer for car is the easiest and most cost-effective way to replace bass that is inevitably lost in a vehicle interior. The KSC-SW10 amplified subwoofer features a 150W max power amplifier with a dual voice coil 180mm concave woofer, and a 180mm concave passive radiator. The Kenwood KSC-SW10 with Passive radiator technology produces an impressive bass response from such a compact enclosure - air pressure from the powered woofer moves the passive radiator, magnifying the bass response. The subwoofer, with its 94mm height, can be mounted flat under a seat in the passenger compartment, or in the boot.The subwoofer can be used with any type of car radio due to its ability to accept either line level (RCA) or speaker level.
The Kenwood KSC-SW10 active subwoofer with 35~120Hz frequency range comes with a wired remote that can be attached anywhere convenient in the vehicle using the supplied Velcro strip. The active subwoofer measures 369×224×94mm, weighs 3.4kg and will be available in Japan from mid may for approximately 22,050 Yen ($185)
Kenwood active sub woofer KSC-SW50
The Kenwood active subwoofer KSC-SW50 features a 300W max power amplifier with a 200mm cone active speaker. The Kenwood KSC-SW50 with built ALC (automatic level control) circuit holds down the distortion to a great extent. The wired remote control provides fingertip control of your system's bass. You can use it to raise or lower the bass volume and the crossover frequency, as well as switch the phase from 0° to 180°. The remote control can be attached anywhere convenient in the vehicle using the supplied Velcro strip.
Kenwood active sub woofer KSC-SW50 is supplied with instructions, mounting hardware and pre-wired connectors and remote. The subwoofer measures 358×210×314mm, weighs 8.1kg and will be available in Japan from mid May for approximately 36,750 Yen ($310).
venar
