Klipsh SB-3
Καινούργια μέσα στο κουτί τους.
Τιμή: 550 ευρώ
Sensitivity: 94dB @ 1 watt / 1 meter
Bandwidth: 52Hz–20kHz±3dB
Nominal Impedance: 8 ohms
Crossover Frequency: 2700Hz
Power Handling: 100 watts maximum continuous
(400 watts peak)
Enclosure Type: Bass reflex via wide flare, rear-firing port
Drive Components: Two-way system using one 1" (2.54cm)
K-101-S neodymium magnet, aluminum dome compres-
sion driver with a 90° x 60° Tractrix Horn and one
8" (20.3cm) K-1093-SB magnetically shielded
woofer featuring a polymer housing and IMG cone
Net Weight: 18 lbs. (8.18kg)
Height: 17" (43.18cm)
Width: 8.69" (22.06cm)
Depth: 11.25" (28.57cm)
Cabinet: Medium density fiber board construction (MDF)
Finish: Woodgrain vinyl veneer
seos
