ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
http://www.projectorreviews.com/lg/cf3d/index.phpIt's the 3D! I can't imagine anyone really needs to spend close to $15,000 for a 2D projector with only 2500 lumens, no interchangeable lenses, and only a dual lamp system for real uniqueness. You can buy brighter commercial projectors for 1/3 the cost. Many of those will be 3LCD or single chip DLP's but there will even be 3 chip DLP projectors available for less (and brighter). The point is, you will only buy a CF3D projector if you have 3D applications.
From a price check standpoint, the competiton looks a bit like this: Digital Projection offers a $20,000 single chip DLP, the new M Series 3D projector, claiming over double the lumens (5500), but is an active system requiring active 3D glasses. As such, a high brightness projector like that will likely be used with large audiences, so do figure thousands extra, to equip 50 or 100 people with the still pricey active shutter glasses. The DP is definitely more money, more power, if you must have big room abilities.
Sony offers a $10,000 SXRD (LCoS) 3D projector for the home, their VPL-VW90ES which should have an excellent picture, but is only rated at 40% of the brightness of the LG, so probably will stay "at home" since it isn't likely to be able to put even 400 lumens up on the screen in 3D.
Low cost, bright single chip 3D DLP projectors are hitting as well. Viewsonic has their Pro8500 for example - 5000 lumens (active - needs the expensive shutter glasses). It's MSRP is only $2299, but then, it's not exactly apples to apples. The Viewsonic is only XGA resolution, which from a practical standpoint is less than 1/4 the resolution (number of pixels) of a 1080p projector like this LG. XGA is definitely lower than nomrlaly used for most scientific, rendering, architecture, type applications. That is, the Viewsonic may be affordable, and bright, but the commercial applications that are primarily being used with 3D, are too high for the Viewsonic projector. (That's not to say it isn't suitable for classroom use.)
The LG CF3D is a first generation passive 3D LCoS projector. It will need a 3D surfaced screen for 3D, but will save a fortune by needing only passive glasses (6 pair come with the LG). Color is excellent, it's bright enough for commercial applications in small and medium sized rooms as long is there is some reasonably good lighting control (without trying to fully darken the room).
And 3D looks rather excellent! All the demo software looked great, give or take some crosstalk and some screen type noise. The LG CF3D is definitely a viable projector for 3D wherever budget allows.
