LG LE8500 Infinia Reviews Εντυπώσεις Κατόχων
Ένα σκαλί κάτω απ τις 3d υπάρχει αυτή η σειρά της LG με local dimming (συστήματος I.O.P.)
Πηγή: FlatpanelsHD
Energy consumption
Energy consumption on LG LE8500 has been measured below.
Out-of-Box After calibration
Standby 0,0 W 0,0 W
SD 79 W 57 W
HD 79 W 57 W
Conclusion
LG LE8500 features a new and quite unique LED conduction from LG that allows the TV to be very slim and at the same time utilize local dimming. Until now this has not been possible. LE8500 has a design with a glass front covering both panel and bezel which looks good. However, it also introduces a lot of reflections.
Most inputs are pointing towards the wall which is a problem. The DLNA and NetCast features are nothing too exciting either. They’re there and working but it’s they’re also limited. If you want to playback DivX you should use the USB.
The picture quality on LE8500 is impressive. The scanning backlight system improves response time and motion resolution considerably the same way it did on the SL8000 (SL80) model. Color reproduction is fair. Black depth is very, very deep and close to perfect because of the LED local dimming backlight but it also has some disadvantages such as horizontal banding and halos.
LE8500 is without doubt one of the most interesting LCD-TVs this year, and the scanning backlight and local dimming technologies are significant improvements to the LCD panel technology. It comes at higher price than most LCD-TVs but I’m very convinced by the LE8500 model and hereby Awards it with our Highly Recommended Award.
Tιμές Ελλάδας
Με αφορμή όμως το εν λόγω review αλλά και ένα preview του fullhd θα ήθελα να σταθούμε σε μερικά σημεία:
1)
Actually my measuring equipment gave me 0,0 cd/m2 for black and this suggests that black levels on LE8500 are perfect or very close to perfect.
Σχετικά με την κλίμακα του γκρι, η τηλεόραση κλείνει εντελώς τον οπίσθιο φωτισμό σε 100% μαύρο, ενώ ‘κλειδώνει' το μαύρο στα 0,02 nits όταν στην εικόνα φωτιστεί σε κάποιο σημείο.
Οι μετρήσεις που λάβαμε ήταν οι ακόλουθες με σήμα video:
Σε παράθυρο 10% λευκό σε 100% μαύρο φόντο, (φωτεινότητα κορυφής) το μαύρο έδωσε 0,02nits και το λευκό 85,9
Σε παράθυρο 25% λευκό σε 100% μαύρο φόντο το μαύρο έδωσε 0,02 nits και το λευκό 115 nits.
Σε παράθυρο 100% μαύρο (συνολική φωτεινότητα) το μαύρο μηδενίσθηκε και το 100% λευκό άγγιξε τα 120 nits.
Στην σκακιέρα το μαύρο κλείδωσε στα 0,02 nits και η φωτεινότητα κυμάνθηκε από 104 έως 114 nits, εύρος που δίνει μία ακρίβεια στην κατανομή της τάξεως του 92%.
Τα παραπάνω στοιχεία φέρνουν στην επιφάνεια ότι η δυναμική αντίθεση, με εκτίμηση στάθμης μαύρου 0,01 nits αγγίζει το 12000:1 ή και παραπάνω, ενώ η πραγματική αντίθεση που προκύπτει από την σκακιέρα φθάνει στο 5700:1.
Επιτέλους ΜΑΥΡΟ από τηλεόραση και δη lcd!
2)
LG LE8500 has zero clouding. The local dimming system ensures almost perfect blacks and there are no light homogeneity issues.
Eλπίζω να μήν έτυχε..αλλά να πέτυχε!
3)
Παρόλα αυτά όμως έχουμε ολίγον ''σκοταδισμό'' σε χαμηλά IRE,οπότε χάνει κάπως σε shadow detail.Βασικά δεν ξέρω αν υπάρχει αυτή την στιγμή τηλεόραση που να κοντράνει σε αυτό τον τομέα έναν καλό προβολέα(της τάξης του 2000αρου ευρώ και άνω),ανεξαρτήτως τιμής!
However, the LED system is not perfect yet and has some issues with loss in shadow detail and the before mentioned horizontal banding issues. Also, we see this halo effect that we also talked about on previous LED local dimming TV sets.
Απάντηση: LG LE8500 Infinia Reviews Εντυπώσεις Κατόχων
Υπαρχουν και καλυτερες τιμες απο το skroutz...
πχ 47αρα 1330e!
Τελος εβδομαδας περιμενω την 55αρα!
ποσο το μαλλι,αν επιτρεπεται;
Οι τιμες ειναι απο electronet στο Γαλατσι .Β. Καμπερης τηλ 210 2934150-160!
http://www.avforums.com/review/LG-LE8900-47LE8900-Review.html
Aπο το AVforums.com
(Eίναι η ίδια τηλεόραση.Απλώς στην βρετανική αγορά αναφέρεται ως 8900,όπως αντιστοιχως το x9xx υπάρχει και στα άλλα μοντέλα αντί για x5xx που είνα οι κωδικοί σε εμάς)
Pros
  • THX Cinema provides a very accurate preset
  • Reference Greyscale performance after calibration
  • Reference Colour accuracy after calibration
  • Excellent black levels for a LCD display
  • IPS panel provides very good off-axis performance
  • Full array LED backlighting with localised dimming
  • Full ISFccc Calibration controls
  • Freeview HD built in
  • Excellent backlight uniformity
  • Very well designed and responsive menu system
  • Attractive styling and well designed remote
Cons
  • Video deinterlacing could be better
  • Failure to detect 2:2 cadence
  • Internet platform is ather limited
  • Input lag could be better in Game mode
  • Downward facing HDMI inputs would make more sense on an ultra thin display
Απάντηση: Re: LG LE8500 Infinia Reviews Εντυπώσεις Κατόχων
Καλησπερα...Δηλωνω ευτυχης κατοχος της 47le8500....Εχω να πω οτι η τηλεοραση ειναι τελεια...Το μαυρο της που γινεται ολοκληρη ιστορια εχω να πω ειναι σαν της πλασμα u10 που εχω και μπορω να συγκρινω και ισως και καλλυτερο!!!!Πραγματικα ειναι σαν να βλεπεις σε πλασμα...Πολυ καλα χρωματα και ευκρινεια και οσο για το trumotion εκτος οτι εχει να πειραξεις το judder και το blur....ακομα και στο High δεν κανει κανενα artifacts..Συντομα θα μπουν και φωτο....
Καλοθέατη!!
Αναμένουμε το φωτορεπορτάζ.
Για πες μας και λίγα περισσότερα..Στα αναλογικά κανάλια πως είναι;Η usb της τι αρχεία αναγνωρίζει,αν τα πάει καλά με τους υπότιτλους κτλ..
Καλοθέατη!!
Θα ελεγα οτι ειναι πολυ καλη στα αναλογικα και ειδικοτερα στα ψηφιακα καναλια...εχει φοβερα χρωματα η τηλεοραση και επισης πολυ καλη κινηση...επειδη βλεπω και μεσω νοβα θα ελεγα οτι τα ψηφιακα ειναι λιγο καλλυτερα...σε HD Η τηλεοραση απογειωνεται..Οπως ειπα και πριν το μαυρο ειναι μαυρο!!!!!Το μονο ισως κακο γιατι πρεπει να τα λεμε και αυτα ειναι οτι εχει πολλες αντανακλασεις λογω του τζαμιου...Ακομα δεν εχω δοκιμασει usb αλλα πολυ πολυ συντομα θα γινει....λιγο στην αναμονη..
Εχω καταληξει και εγω σε αυτη την σε 55'' περιμενα κανα 4 μηνο την 47LH9000 που απο οτι φαινεται τελικα σε καλο μου βγηκε :114:
Την 47LX9500 την τεσταρα με πολυ hd υλικο επαιζε πολυ καλα εκτος το 3D ξερει κανεις αν εχουν μεγαλες διαφορες σε ποιοτητα εικονας με την LE8500 ??
intergrale
