LG LH-T6740 (entry level Home Cinema)
Amplifier
Power Output-Front (10%THD) 2x90W
Power Output - Center 90W
Power Output - Rear 2x90W
Power Output - Subwoofer(10%THD) 150W
Function DivX (3.11, 4, 5), Xvid, CD/DVD, Video1 (Rear AV), Video2 (Front AV), FM/AM
Interface
Audio Line IN Analog: 2, Digital: 2 (optical, coaxial)
Audio Line OUT No
5.1Ch Input No
Output Terminal(Front/Center/Rear/Subwoofer) x/x/x/x
Preout No
Teminal Type Push in
Video Signal IN 2
Video Signal OUT Composite(monitor), Component, S-video, Scart
Component Switch Component/S-video : OSD, Component/Scart : OSD
Headphone Jack (3.5mm) 1
Audio
Sound Effect DTS, Dolby Digital, Dolby Prologic, Dolby Prologic II, DSP Sound Mode, 2Ch Stereo (By-Pass)
Test Tone Yes
Sound Level Yes
Mute Yes
Display FL
Dimmer Yes
Sleep Yes
Power Save Mode No
Screen Saver Yes
Power
Power Indicator Power on/off : Yes/Yes
Power Requirement Narrow (50/60Hz) : Yes, Wide : No
Power Consumption -
Power Consumption at stand by 1W
Tuner
Type PLL
Band FM/AM
Staton Preset 50
Clear Yes
RDS (PS, PTY, CT, RT) Yes
DVD Player
Type 1 DVD tRAY
Graphic User interface Yes
Progressive Scan Pal & NTSC
Playable Disc Format CD, CD-R/RW, MP3 CD, DVD, DVD±R/RW, DVD Audio, VCD 2.0,SVCD, WMA, JPEG Viewer, Kodak Picture CD
Convenience Zoom, Marker, Marker Search, Repeat 1/All, Repeat A-B, Last Scene Memory,Program play (Track),20 of programable Tracks, Smooth Scan, Smooth Slow, 100x Scan
Remote Cotrol Unit
TV-Multibrand LG TV only
Battery (Size) AAA
Accessories
Instruction Manual Yes
Quick Setup Guide Yes
AM Loop Antenna Yes
FM Antenna Yes
Batteries Yes
Speaker Cable(6Speakers All) Yes
RCA Code(Audio), Red/White, 2P No
RCA Code(Video), Yellow, 1P Yes
S-Video Cable No
Scart Jack Adaptor Yes
Stand for Speakers Yes(Front & Rear)
Main
Size (W x H x D) mm 430 x 65 x 345
Net Weight (Kg) 4,6
Front speaker
System 2 Way, 5 Speaker
Tweeter Unit 13mm Semi Dome
Mid Unit No
Woofer Unit 56mmx4
Detachable Grill Jersey Net
Impedance 6Ω
Magnetic Shielding Perfect
Size (W x H x D) mm 70 x 1200 x 72 (inkl stand)
Net Weight (Kg) 2,8
Rear Speaker
Tweeter unit 13mm Semi Dome
Mid Unit No
Woofer Unit 56mmx4
Impedance 6Ω
Net Weight (Kg) 2,8
Center Speaker
Mid Unit No
Woofer Unit 56mmx4
Impedance 6Ω
Size (W x H x D) mm 440 Χ 88 Χ 77
Net Weight (Kg) 1,8
Subwoofer
System 1Way 1Speaker
Tweeter Unit No
Mid Unit No
Woofer Unit 8
Detachable Grille Jersey Net
Impedance 4Ω
Magnetic Shielding SEMI
Size (W x H x D) mm 195 Χ 380 Χ 417
Net Weight (Kg) 7,2
Τιμουλα στην Ελλαδα?
Άγνωστη (τουλάχιστον σε μένα!! :roll: )
Ρώτα σε κάποια καταστήματα και αν μάθεις ρίξε και ένα post να μας πεις! :wink:
Από προδιαγραφές είναι καλό πάντως.
Να δούμε μόνο την αναλογία κόστους/απόδοσης!
  • loggeo
jimacid
