http://www.avforums.com/review/LG-PK350-50PK350-Review.htmlConclusion
At this price point I would consider the PK350 to be the very definition of a Best Buy. You have a well made and attractively designed display that has a very accurate pre-calibrated setting as well as a comprehensive set of ISF calibration controls. Once properly calibrated the PK350 produces a reference quality performance in both Greyscale and Colour Gamut and the excellent video processing means that both standard definition and high definition images look fantastic. With this kind of performance, at this kind of price I strongly recommend that anyone who is thinking of buying a plasma on a limited budget should take a look at the PK350.
Bρε την Lg..
Tηλέοραση για videophiles(έντάξει πάσχει λίγο με απόλυτα κριτήρια στο μαυρο της) σε τιμή πρόκληση!Λογικά εξαιρετική και στα τηλεοπτικά κανάλια.
