London (Decca) Reference Phono Cartridge
Van den Hul improved!
Πωλείται η βραβευμένη, θρυλική κεφαλή που έθεσε νέα σημεία αναφοράς στην απόλαυση κάθε δίσκου!
  • Σε άριστη κατάσταση.
  • Έχει "παίξει" 300 ώρες.
  • Διατίθεται με την αρχική της συσκευασία.
" How and why is this cartridge different from, and possibly superior to all the others? Is it a "moving coil" or a "moving magnet" design? Neither! Only a lighter, thinner, shorter, magnetically active metal foil bearing the stylus comprises the entire moving system. This results in lower moving mass than either moving coil or moving magnet models. The London Decca cartridges may be the only ones which have no cantilever, at least in the conventional sense. This appears to be the underpinning of their stunning success.
"It has been said that the London Deccas "reek of musicality."
Other cartridges (both moving coil and moving magnet) have styli mounted on the long end of a thin tube (cantilever) which works like a lopsided "see-saw." The short end of the cantilever attaches to either a coil of wire or a magnet. At the fulcrum point, a flexible "rubbery" sleeve functions as a pivot, allowing the stylus/cantilever assembly to respond to the "wiggles" in the LP groove. Because the front section of the cantilever, which holds the stylus, is much longer than the rear section that is attached to the coil or magnet, a large movement of the stylus is transformed to a smaller movement at the coil or magnet, possibly causing cantilever-design cartridges to sound dynamically compressed and lacking in transient attack.
London Decca's engineers advise that this problem with dynamics and transients is compounded by the cantilever's "rubbery" fulcrum point which tends to absorb a significant amount of the stylus-generated motion before it can reach the coil/magnet electrical generator assembly. Also, a smearing of the sound is said to occur, which many folks refer to as "cantilever haze."
The Reference has no long cantilever and no "rubbery" fulcrum point to absorb, dissipate and smear the vital musical energy. Instead, the stylus is attached directly to a magnetically active metal support just a few microns thick (armature) which passes through the center of the main generating coil positioned only about 1 millimeter above the stylus! The stylus motion is not inverted or "transformed" to a smaller value, as in long cantilever designs. Flowing from this immediate positive-direct scanning of the groove is a breathtaking, lifelike quality. "
"The listener tends to feel that the performing artists are actually in the same room, with a startling, palpable presence."
Χαρακτηριστικά
- Frequency Range 20 Hz to 22 Hz +/- 3dB
- Channel Balance 1 dB at 1 kHz
- Channel Separation 25 dB at 1 kHz
- Compliance Lateral 15 x 10-6 cm/dyne - Vertical 10 x 10-6 cm/dyne
- Inductance 130 mH per channel
- DC Resistance 2000 Ohms per channel
- Input Impedance 47 kOhms (optimum 33 kOhms)
- Input Capacitance 100 to 300pF (optimum 220 pF)
- Output 5 mV at 5cm/sec
- Stylus Exclusive line contact
- Playing Weight 1.5 to 2 grams (optimum 1.8 gr)
Τιμή πώλησης: 2.400€
Παρακαλώ θερμά, όχι ανταλλαγές.
Εντός Αθήνας χέρι με χέρι και αποστολή σε όλη την Ελλάδα.
Δεκτή η αποστολή και στο εξωτερικό, κατόπιν συνεννόησης.
Katerinanota
