Lumagen Radiance Pro 4242
Lumagen Radiance Pro 4242 Πωλείται!
Πλήρης κατάσταση λειτουργίας, και γνήσιο κουτί με γνήσια αξεσουάρ. Διαθέτει 2εισόδους x 18gb, έξοδο 1 x 18gb και έξοδο ήχου.
Τιμη 3200 ευρω
Key Features:
-Up to four 4k60 UltraHD inputs
-two processed 4k60 UltraHD outputs
-Inputs and outputs support HDMI 1.x and HDMI 2.0, with HDCP 1.x or HDCP 2.2, at up to 4k60
-Outputs are independently programmable for video, audio, or both
-Modular I/O allows upgrading to new HDMI technology as it becomes available
-Proprietary Lumagen NoRing™ scaling
-DARBEE Digital Visual Presence (DVP) enhancement technology for up to 2K sources
-Vertical keystone correction
-Supports complete processing of 2D or 3D sources on processed outputs
-10-bit front-end, with 12+ bits in calibration pipeline
-Per-pixel SD/HD video deinterlacing
-4913 point (17x17x17) CMS
-Rec2020 colorspace and HDR10 and HLG supported
-21-point Parametric Greyscale calibration
-Anamorphic screen support for up to 4k sources with and without an anamorphic lens
-Supports complete processing of 2D and 3D sources
Κωνσταντίνος Παντός
