LyngBox by Lyngsat.....
Χρήστος Ακρατόπουλος
Πολύ ενδιαφέρον και κυκλοφορεί επίσημα αύριο...
Να δούμε όλες τις λειτουργίες του και να δούμε αν μπορούμε να το "δούμε" και από κοντά...
Technical Features
* HDTV support (720p and 1080i)
* Supports H.264/MPEG-4 AVC and MPEG-2
* Inbuilt tuners for both satellite TV (DVB-S/DVB-S2) and terrestrial TV (DVB-T)
* Internal slot system which makes it possible to install an additional tuner card
* 4:3 and 16:9 TV screen format support and teletext decoding
* Dual Common Interface slots for usage with pay-TV-channels
* PVR functionality with inbuilt hard disk
* Possibilities to store recordings on an external DVD-recorder connected with USB2
* DiSEqC 1.2 support for controlling LNB and motorised dish
* Remote control as standard and a wireless remote keyboard as accessories
* Channel selection by typing the name (or the beginning of the name) of the channel on the keyboard
* View images from a digital camera connected to the LyngBox
* The LyngBox can store up to 50000 channels
LyngBox Special Features
* Free access to all LyngSat Network services (LyngSat, LyngSat Guide and LyngSat Maps) with exclusivity to the LyngBox. No other receiver has access to these services
* Always corrects channel names, not relying on service names in the DVB stream
* Family user profiles and parental lock. Each user can have their own selection of channels based on countries, languages and genres which will be updated automatically
Interfaces
* DVB-S2 input
* DVB-T input + output (pass-through)
* Expansion slot for additional tuner card
* 2 Common Interface slots
* HDMI-output.
* Component output
* Composite output
* SCART output (RGB and composite)
* S/PDIF optical output with AC-3 support
* Stereo audio (2 RCA)
* 4 USB 2.0 ports
* Ethernet connection (100BaseT)
Hardware Specifications
* Size (WxHxD): AxBxC cm
* STi7100 CPU (three cores: 1x266 MHz, 2x400 MHz)
* 96 MB System Memory
* 160 GB Hard Disk
* OLED front panel display
Guarantee & Warranty
* The LyngBox has a two years limited guarantee
Features
The LyngBox is a unique and easy to use product for the world wide market. It solves the most common problems experienced by users. The features of the LyngBox include the following:
LyngBox is a receiver for HDTV
The LyngBox supports HDTV reception, from both satellite (DVB-S2) and terrestrial transmissions (DVB-T). The box has a DVB-S2 tuner to support the latest standard for satellite transmission.
LyngSat Network
The LyngBox uses a number of services from LyngSat Network, some of them specially developed for the LyngBox:
* LyngSat provides the LyngBox with up-to-date channel and satellite information
* LyngSat Maps automatically calculates which satellites that can be received from the users location with the available equipment
* LyngSat Guide is an extensive TV guide
Automatic Channel List Installation
One of the biggest problems with satellite TV is that the channel list in a conventional satellite receiver is static. It requires a lot of knowledge of the user to add new channels, so much knowledge that many viewers avoid watching the ever increasing selection of satellite TV channels.
The LyngBox can use LyngSat Network to automatically install all receivable channels.
Automatic Channel Update
A common problem is that channels seem to disappear suddenly. The reason is that TV companies want to optimize their coverage area and/or decrease their transmission costs. The viewer will think that the channel has stopped transmitting, since there is normally no tuning advice or information about the move.
With the LyngBox, all channel information is automatically updated from LyngSat Network, so the viewer is not affected when the channel moves or changes parameters.
Focus on free-to-air TV channels
The LyngBox simplifies identification, installation, and updates of the large number of free-to-air channels available. The integration of LyngSat Network let the user identify all channels that are possible to install with the available equipment.
Users with a motorized antenna have an additional advantage with the LyngBox. It might be possible to keep track of all channels at one satellite position, but to do it for all receivable satellite positions is almost a full-time job. Many users don't even know which satellates they can tune in. The integration with LyngSat Maps automates this work. The channel list is ready and kept up-to-date without any effort.
You can also watch channels with conditional access by installing "pay-TV-cards" in the dual common interface slots of the LyngBox.
A global and interactive TV guide
LyngSat Guide provides the user with and interactive TV guide. The guide is integrated into the LyngBox, but can also be used as a standalone website.
One-Touch Recording
The integration with LyngSat Guide makes it easy to schedule recordings. Just press the recording button when browsing the TV guide to record a program. The powerful PVR also gives the possiblity to edit recorded programs and to store recordings on an external DVD recorder (connected with USB2).
Control Recordings From Internet
The user can command the LyngBox to record TV programs using the website LyngSat Guide, from any computer with an Internet connection.
There is no need to worry if you forgot to set a recording before leaving home. Just log in on the LyngSat Guide website and set new recordings.
The receiver is developed with focus on quality reception and ease of use
The sensitive DVB-S2 tuner in the LyngBox can tune in to satellites other receivers cannot reach.
Usability for the LyngBox is guaranteed by the intuitive user interface and the automatic channel maintenance enabled by the integration with LyngSat Network. The user can concentrate on the main objective: watching TV.
Dual Tuner
Dual Tuners makes it possible to watch and record both terrestrial and (DVB-T) and satellite (DVB-S/S2) channels. A third tuner is possible to add as an option for simultanous watching and recording from the same source.
Photo Viewer
The LyngBox can display your photos in full HDTV resolution. It is possible to connect a digital camera to the USB connectors and display photos, or copy the photos to the built-in hard disk of the LyngBox.
User Profiles
Each user of the LyngBox can have his or her own profile with separate channel lists. The channel lists for all profiles are of course kept up-to-date with the LyngSat synchronization. It is possible to protect profiles with password (parental lock).
Note: Since the LyngBox communicates with LyngSat Network over the Internet, it is recommended to have an Internet connection to the LyngBox.
απόκαλύφτ...!!
Ο Σουηδός Cristian Lyngemark γνωστός εδώ και μια δεκαετία στον χώρο της δορυφορικής τηλεόρασης, ιδρυτής της ιστοσελίδας www.lyngsat.com που ασχολείται με την ταξινόμηση και καταγραφή όλων των καναλιών που εκπέμπουν σε όλους τους δορυφόρους του Γεωστατικού τόξου, σε συνεργασία με την European Space Agencies (ESA) παρουσίασαν ένα νέο δορυφορικό δέκτη τον Lyngbox.
O Δορυφορικός δέκτης αυτός από τα πρώτα τεχνικά χαρακτηριστικά και τις πρώτες περιγραφές, φαντάζει σαν απάντηση στα όνειρα πολλών δορυφορομανών. Ας ξεκινήσουμε την όσο πιο λεπτομερή παρουσίαση του μπορούμε να κάνουμε πάντα βασιζόμενοι στις αναφορές που βρήκαμε στο διαδίκτυο. Φίλος επαγγελματίας εισαγωγέας δορυφορικών μηχανημάτων, υποσχέθηκε να μας τον δώσει για αποκλειστικό review αμέσως μόλις φτάσει το πρώτο δείγμα.
Ο Lyngbox είναι
Technical Features
- HDTV support (720p and 1080i)
- Υποστηρίζει H.264/MPEG-4 AVC and MPEG-2
- Ενσωματωμένα tuners για ψηφιακή δορυφορική TV (DVB-S/DVB-S2) αλλά και επίγεια ψηφιακήTV (DVB-T)
- Εσωτερική υποδοχή για 3ο tuner card
- Υποστήριξη 4:3 and 16:9 TV
- Αποκωδικοποίηση Teletext
- Διπλή θέση για Common Interface για κωδικοποιημένες εκπομπές
- PVR εγγραφές σε εσωτερικό σκληρό δίσκο
- Δυνατότητα για αποθήκευση των εγγραφών μας σε εξωτερικό DVD recorder συνδεμένο μεσω USB2
- DiSEqC 1.2 support για έλεγχο των LNB και κινητού πιάτου
- Remote control as standard και ασύρματο υποστηριζόμενο πληκτρολόγιο.
- Επιλογή καναλιών με πληκτρολόγηση του ονόματος του καναλιού στο ασύρματο υποστηριζόμενο πληκτρολόγιο
- Παρουσίαση φωτογραφιών από ψηφιακή κάμερα συνδεμένη στο LyngBox
- Χωρητικότητα 50,000 καναλιών
- Δωρεάν πρόσβαση στα LyngSat Network services (LyngSat, LyngSat Guide and LyngSat Maps) αποκλειστικά για το LyngBox. Παγκόσμια πρωτιά, καθώς δεν υπάρχει άλλος δέκτης με τέτοια ευκολία.
- Μετονομασία των ονομάτων καναλιών με γνώμωνα το Lyngsat και όχι το όνομα που περιλαμβάνεται στο DVB stream
- Family user profiles and parental lock. Each user can have their own selection of channels based on countries, languages and genres which will be updated automatically
Interfaces
- DVB-S2 input
- DVB-T input + output (pass-through)
- Expansion slot for additional tuner card
- 2 Common Interface slots
- HDMI-output.
- Component output
- Composite output
- SCART output (RGB and composite)
- S/PDIF optical output with AC-3 support
- Stereo audio (2 RCA)
- 4 USB 2.0 ports
- Ethernet connection (100BaseT)
- Size (WxHxD): AxBxC cm
- STi7100 CPU (three cores: 1x266 MHz, 2x400 MHz)
- 96 MB System Memory
- 160 GB Hard Disk
- OLED front panel display
- The LyngBox has a two years limited guarantee
Το LyngBox προσπαθεί να λύσει τα συχνότερα προβλήματα που οι απλοί χρήστες δορυφορικών δεκτών συναντούν. Τα χαρακτηριστικά του LyngBox περιλαμβάνουν:
Το LyngBox είναι δέκτης για την HDTV
Το LyngBox υποστηρίζει λήψη HDTV (Υψηλής ευκρίνειας), τόσο από δορυφορική εκπομπή (DVB-S2) όσο και από επίγεια ψηφιακή (DVB-T). Ο δέκτης διαθέτει και DVB-S2 tuner για υποστήριξη όλων των δορυφορικών εκπομπών.
LyngSat Network
Το LyngBox συνδέεται με το LyngSat Network, που παρέχει ειδικές ευκολίες για τον δέκτη αυτό:
- Το LyngSat παρέχει στο LyngBox ενημερωμένες λίστες καναλιών και δορυφορικών πληροφοριών
- Το LyngSat έχει ΧΑΡΤΕΣ που αυτόματα αναγνωρίζουν ποιών δορυφόρων η λήψη είναι εφικτή από την γεωγραφική τοποθεσία όπου βρίσκεται ο δέκτης εγκατεστημένος (συναρτήσει περιοχής και δορυφορικού εξοπλισμού)
- Το LyngSat Guide είναι ένας λεπτομερής Τηλεοπτικός Οδηγός (TV guide)
Αυτόματη Εγκατάσταση αλλά και ενημέρωση Καναλιών
Ένα από τα μεγαλύτερα προβλήματα με την δορυφορική λήψη είναι ότι όλες οι λίστες των δορυφορικών εκπομπών αλλάζουν με καθημερινή συχνότητα. Οι αποθηκευμένες λίστες στους δέκτες είναι στατικές και για να αναγνωριστούν οι αλλαγές πρέπει να ξανακάνουμε σάρωση, χάνοντας πολλές από τις ρυθμίσεις μας, κάτι που πολλές φορές μας αποτρέπει να βάλουμε καινούργια κανάλια με τον φόβο να χάσουμε τα παλαιά μας!. Στο LyngBox μια απλή ενημέρωση από το LyngSat Network απαιτείται για την αρχική εγκατάσταση όσο και την επιθυμητή ενημέρωση νέων καναλιών ή παύση λειτουργίας καναλιών..
Τηλεοπτικός Οδηγός (interactive TV guide)
Το LyngSat Guide παρέχει στον χρήστη με ενανε πάντα ενημερωμένο τηλεοπτικό οδηγό. Ο οδηγός αυτός αποτελέι μέρος του LyngBox, και σε συνεργασία με τον ενσωματωμένο σκληρό δίσκο ευκολύνει τις εγγραφές μας.
Εγγραφή σε Σκληρό δίσκο (One-Touch Recording)
Όπως αναφέραμε η συνεργασία με το LyngSat Guide ευκολύνει τον προγραμματισμό εγγραφών. Επίσης όποιες εγγραφές έχουμε στον σκληρό δίσκο μας μπορούμε να τις μοντάρουμε ή να τις αποθηκέυσουμε στο εξωτερικό DVD recorder (συνδεδεμένο μέσω USB2).
Dual Tuner
Photo Viewer
User Profiles
Πολύ ενδιαφέρον, αλλά δεν κατάλαβα...
-Μπορεί να βλέπουμε ένα κανάλι και να γράφει άλλο ή άλλα και αν ναι πόσα;
-Μπορεί να κάνει pause, rewind κτλ στο live πρόγραμμα;
Μαλλον λεει οτι μπορεις να εγγραφεις επιγειο και να βλεπεις δορυφορικο ή το αντιθετο και μπορει να προστεθει και ενας 3ος που τον αναφερει σαν οptional.
Σωστα παιδες ?
Ακομα dial ; ή ενταξει το dsl ?
ΠΟΛΥ ΚΑΛΟ ΦΑΙΝΕΤΑΙ
Εαν το "δουμε" απο κοντα και αξιζει , να κανουμε ενα "POWER-BUY" για το συγκεκριμενο
Πληροφορίες απο άλλο forum:
Features
The LyngBox is a unique and easy to use product for the world wide market. It solves the most common problems experienced by users. The main features of the LyngBox include the following:
LyngSat Network
* LyngSat Guide is an extensive TV guide covering all the world
One of the biggest problems with satellite TV is that the channel list in a conventional satellite receiver is static. It requires a lot of knowledge by the user to add new channels, so much knowledge that many viewers avoid watching the ever increasing selection of satellite TV channels.
To know if a channel is receivable with a specific type of equipment, the LyngBox can use LyngSat Network to automatically install all receivable channels.
The LyngBox simplifies identification, installation, and updates of the large number of Free-to-Air channels available. The integration of LyngSat Network let the user identify all channels that are possible to install with the available equipment.
Users with a motorized antenna have an additional advantage from the LyngBox. It might be possible to keep track of all channels at one satellite position, but to do it for all receivable satellite positions is almost a full-time job. Many users don't even know which satellates they can tune in to. The integration with LyngSat Maps automates this work. The channel list is ready and kept up-to-date without any effort.
LyngSat Guide provides the user with a global and interactive TV guide. The guide is integrated into the LyngBox, but can also be used as a standalone website.
One-Touch Recording
The integration with LyngSat Guide makes it easy to schedule recordings. Just press the recording button when browsing the TV guide to record a program. The powerful PVR also give the possiblity to edit recorded programs and to store recordings on an external DVD-recorder connected with USB2.
The user can command the LyngBox to record TV programs using the webbsite LyngSat Guide, from any computer with an Internet connection.
You don´t need to be worried if you forgot to set a recording before leaving home. Just log in on the LyngSat Guide website and set new recordings
The sensitive DVB-S2 tuner in the LyngBox can tune in to satellites other receivers can not reach.
Usability for the LyngBox is guaranteed by the intuitive user interface and the automatic channel maintenance enabled by the integration with LyngSat Network. The user can concentrate on the main objective, watching TV
Dual Tuner
Makes it possible to watch and record both terrestrial and (DVB-T) and satellite (DVB-S/S2) channels. A third tuner is possible to add as an option for simultanous watching and recording from the same source.
Photo Viewer
The LyngBox can display your photos in full HDTV resolution. It is possible to connect a digital camera to the USB-connectors and display photos, or copy the photos to the inbuilt hard disk of the LyngBox.
User Profiles
Each user of the LyngBox can have an own profile with separate channel lists. The channel lists for all profiles are of course kept up-to-date with the LyngSat synchronization. It is possible to protect profiles with password (parental lock).
__________________
ΑΝΔΡΕΑΣ Κ. said:
Να κανουμε καμμια κινηση? :wink:
δεν είναι κακιά ιδέα αλλά μικρές επιφυλάξεις...
λόγω υπερνομοτυπίας του Lyngemark το μηχανάκι αυτό μήν περιμένετε καθόλου να έχει παρα-λογισμικά και "ξεκλειδώματα"... άρα θα είναι καθαρός υπερ-ανταγωνιστής ενός δέκτη τύπου Humax 2000 με προσθήκη πολλών ακόμα δυνατοτήτων (PVR, channel updates, etc etc).
Ομως ο νέος Dreambox θα εχει καλές προοπτικές, αλλά αργεί ακόμα.
Αν μάθουμε τιμή για το Lyngbox και ίσως τον δούμε απο κοντά έτσι θα ξέρουμε πόσο μαγκιόρικο δεκτάκι είναι
Xatzisjim
