Lynx Studio Technology: Hilo Reference A/D D/A Converter System
Κώστας Φ.
Για τον Κωσταυτιά με πολύ αγάπη... :116:
Lynx Studio Technology is proud to present the Hilo Reference A/D D/A Converter System.
Crucial for mastering and critical listening, Hilo offers world class, verifiable specifications. Actual measurements of a preproduction model show:
LINE IN PERFORMANCE THD+N -114dB @1kHz, -1dBFS, 20kHz filter Dynamic Range 121 dB, A-weighted, -60dBFS signal method Frequency Resp. ± 0.01 dB, 20 – 20kHz Crosstalk 130 dB maximum @ 1kHz, -1dBFS signal
LINE OUT PERFORMANCE THD+N -109dB @1kHz, -1dBFS, 20kHz filter Dynamic Range 121 dB, A- weighted, -60dBFS signal method Frequency Resp. ± 0.01 dB, 20 – 20kHz Crosstalk -120 dB maximum @ 1kHz, -1dBFS signal
Available in the second half of 2011, the US suggested retail price is expected to be $2495.
Basically, Hilo replaces three different, critical components:
#1 Hilo is an analog to digital converter
#2 It is also a digital to analog converter. With most companies, these are two separate units.
#3 It is an independent headphone amplifier. The headphone section has its own, dedicated D/A converter. This provides two key benefits. First this allows Hilo to offer a headphone output with exceptional clarity and noise specifications. Second, due to Hilo’s internal 32 channel mixer, any input set can be routed to the headphone stereo output. This means that a mix that is entirely different from the analog outputs and monitors can be applied to the headphones.
Hilo is a 3 in one unit – AD converter, DA converter and Headphone with its own dedicated D/A converter.
There are three sets of analog outputs: main analog output, monitor output (with volume) and headphone output (with volume)
The flexible digital I/O section offers the choice of AES/EBU, SPDIF by coax or TOSLINK optical, or ADAT formats
The innovative design of the analog stage and converter topology allow ultra low noise and distortion specifications
A 480 x 272 pixel LCD touch screen for operation and monitoring
A 32 channel internal mixer in the updatable FPGA
12 total inputs, 16 total outputs plus 32 channels possible via LSlot.
AC powered with Battery operation available
Open ended software for future measurement, metering, diagnostic and personalization features using the touch screen LCD.
Περισσότερα: LynxStudio
Κώστας Φ.
To USB του είναι αυτό, αλλά έρχεται ως extra στα $395.
  • One USB Device port, using USB 2.0 protocol
  • Class compliant USB Audio 2.0 high speed card
  • Supports 16 I/O channels at 96 kHz (Aurora 16), 8 I/O channels at 192 kHz (Aurora 8). All bidirectional.
  • Compatible with Macintosh OS X 10.6.4 and up
  • Compatible with Windows XP/Vista/7, 32 and 64 bit drivers
  • Utilizes Lynx Studio Technology’s proprietary SynchroLock™ technology to virtually eliminate USB bus jitter when slaving Aurora to USB
Manos58
εγχειρισμένη
Απάντηση: Lynx Studio Technology: Hilo Reference A/D D/A Converter System
Ατιμη Κρητικιά δεν τον λυπάσαι....................
Μπαλωθιές :617:του ρίχνεις και είναι και αδυνάτου κράσεως....................θα μας κρασάρει
vlasis
Φωτογράφος!
Hilo η Lynx-------Hallo η Metric............πολλες χαιρετουρες μας ριχνουν οι παλιοΑμερικανοι!!!!!!!!!!!!!!!:125::125::123:
αχ... τι οπίσθια είν'τούτα βρε! μου βγήκαν τα μάτχια...:428::428::428::428:
κοίτα και κάτι ματάρες που έχει το χρυσό μου:
Re: Απάντηση: Lynx Studio Technology: Hilo Reference A/D D/A Converter System
Χάθηκε να βάλουν και κανένα unbalanced-in?
Πόσο πάει το μαλλί? (Α! Βρήκα...στα $2500)
Το μαυρομούρικο είναι τρελό μωρό...
αχ βαχ...
παλιο-δέλτα-νι-τάφ...
σαν καλο μου φενεται να το παρω τωρα η να περιμενω λιγο ακομα μπας και πεσει η τιμη του και το παρω μαζι με την μπομποτα ? το φθινοπωρο ?
Δεν θα ησυχάσουμε ποτέ.......
Άτιμο ΔΝΤ!!!!!!
το ξέραμε αγαπητέ πως πρόκειται για μηχανάρα με αρ@@@@ια, η οποία (ευτυχώς) ΔΕΝ πρόκειται να πέσει στα χέρια του αλλουνού του ποιητή της κακιάς ώρας που "τέσταρε cd-player's" τρομάρα του...
ιδέαν δεν έχω (ούτε για το ένα, ούτε για το άλλο)
να κι ένα ριβιού από μένα:
:116::116:
Manos58
εγχειρισμένη
Τις υγρές μεσαίες μου ..........
Βλάσηηηηηηηηηηηηηηηηηηηηηηηηηηηηηη έχει τέτχια η Metric ?
Ki αν ναι γιατί δεν τα βλέπουμε εμείς ???????????????????????????????
dark2030@
