M2Tech news...
Κώστας Φ.
Marco Manunta's M2Tech company announces the hiFace Evo USB-to-S/PDIF interface based on the hiFace but improved and housed in a brushed aluminum case (105 x 100 x 46mm) with B-type female USB connector.
It has inputs for an external 7 to 11VDC PSU; external master clock (BNC on transformer); RCA and 75-ohm BNC; AES/EBU with XLR connector and selectable consumer or pro standard via internal jumper; Toslink, ST and direct I²S outputs with 3.3V interface.
All outputs except I²S are transformer-decoupled to avoid ground noise and EMI interference. Three LEDs indicate power, data stream on input and external clock presence.
The new 384/32 Young DAC sits in a brushed aluminum case measuring 200 x 50 x 200mm. It includes input sampling frequencies of 44.1, 48, 88.2, 96, 176.4, 192, 352.8* and 384kHz* (* USB only); up to 32-bit resolution on USB, 24 bits on all other inputs; USB B-type female, S/PDIF (RCA and 75-ohm BNC), AES/EBU XLR and Toslink inputs; single-ended RCA outputs; and an external 9 - 24VDC power supply.
The new 384/32 Vaughan DAC occupies a 440 x 80 x 440mm enclosure with the same sampling frequencies as the Young, albeit applicable to all inputs at the highest rates.
It then expands inputs to USB B-type female; 2 x RCA and 75-ohm BNC each; dual AES, Toslink and ST for 384kHz respectively; straight I²S and an external master clock link. Outputs are RCA and XLR plus 6.3mm headphone. The power supply is a 115/230VA unit with an optional high-current Lithium battery with battery changer. The Vaughan is M2Tech's reference DAC and sports eight converter chips, four per channel in mono mode. A digital dithered volume control allows amp-direct connection and the headphone output runs a discrete-parts amplifier.
6moons.com
Απάντηση: M2Tech news...
Κανε μας και μια αναλυση.
Εσυ εχεις κανει διατριβη στο M2tech!!
πάντως οι ατάκες του site είναι ασύλληπτα αστείες.βρε τί μου θυμίζουν...
Κώστας Φ.
Δεν ξέρω κάτι για τιμές.
Ελπίζω να κάνουν την έκπληξη να βάλουν κανένα Sabre μέσα αν και χλωμό...
σατανική η ιδέα σου....
μπορείς να τους την πουλήσεις!
Kesus
