MAC AUDIO Z4100 ΕΝΙΣΧΥΤΗΣ 4 ΚΑΝΑΛΟΣ ΑΥΤΟΚΙΝΗΤΟΥ 4Χ160
Max. power output* into 4 Ω4x160 / 2x500 Watt
RMS power output** into 4 Ω4x80 / 2x230 Watt
Max. power output* into 2 Ω4x210 Watt
RMS power output** into 2 Ω4x105 Watt
Frequency response5 Hz – 50 kHz (-3 dB)
THD< 0,05 %
Signal-to-noise ratio> 100 dB
Input sensitivity0,2 V - 5 V
Dimensions (W x L x D)355 x 54 x 293 mm
Input impedance25 kOhm
Power impedance12 V minus an Masse
Weight4,75 Kg
Highlights
Aluminium heatsink with high-gloss white lacquer
2 ohm stable
Low level RCA outputs
Encapsulated power and speaker connectors
Channel mode selector switch 4/3/2 CH
Bridge-/Tri-mode capability
Protection circuit that safeguards against short circuits, DC-offset and overheating
Green operation and red protection indication LED
Variable full-feature-filters:
Low Pass 50 – 250 Hz (12 dB/Octave)
High Pass 40 – 500 Hz (12 dB/Octave)
Bass Boost 0...12 dB at 45 Hz
100 ΕΥΡΩ!!!
Απάντηση: MAC AUDIO Z4100 ΕΝΙΣΧΥΤΗΣ 4 ΚΑΝΑΛΟΣ ΑΥΤΟΚΙΝΗΤΟΥ 4Χ160
100 euro ειναι σημειωμενο απο κατω
Κωνσταντίνος Παντός
