Magnum Dynalab MD-106T Triode Tuner
Magnum Dynalab
SPECIFICATIONS
50 Db quieting - stereo 25.0 dBf
capture ratio - > 1.5 dB
image rejection - 110.0 dB
signal to noise ratio 80.0 dB
alternate channel - wide 70.0 dB
alternate channel - narrow 80.0 dB
adjacent channel - wide 3.0 dB
adjacent channel - narrow 35.0 dB
THD - mono 0.10%
THD - stereo 0.10%
stereo separation 50.0 dB
AM suppression 70.0 dB
SCA rejection 80.0 dB
I.F. Rejection 80.0 dB
19 Khz and 38 Khz component rejection 75.0 dB
audio frequency response (+/_ 1dB) 15 Hz - 17 Khz
balanced audio output (600 ohms) 3.0 V
line audio output (RCA) 1.5 V
line power 20/220/230/240 Vac
dimensions - (inches HWD) 4.5 x 19 x.15
dimensions - (cm HWD) 11.43 x 48.3 x 38.1
weight (lbs./Kg) 16/7.1
power consumption (typ/max) 30/40 VA
Tube Specifications
Anode Current (1) 5 MA
Anode Current (2) (max) 1.07 mA (min) 0.92
Total Harmonic Distortion < .25%
Gain from 6922 Tube 12 Db
Feedback Zero
* MD 106T and 102T, test sheets are included in the tube box.
OPTION - ANALOG Remote Control
Certain manufacturers feel that in order to build a remote-controlled tuner the signal in the front end must be digitized, whereas we at Magnum Dynalab feel that this is where the problems start when you are trying to produce the best sound. We have designed a special ANALOG remote control which maintains the finite tuning and sound produced with our ANALOG tuners. The remote is optional and can be added to any of our tuners at any time.
Features of the Magnum Dynalab ANALOG Remote
On/Off switch
Five station presets
Remote fine tuning
REVIEW:
http://www.enjoythemusic.com/magazine/equipment/1204/magnumdynalabmd106t.htm
TRULY HIGH END FM RECEPTION !
Nikos88
