Marantz AV7704 Προενισχυτής Home Cinema 4K 11.2 Καναλιών με HDR και Dolby Atmos, DTS:X και AURO 3D
σε άριστη κατάσταση, αγρατζούνιστος, σε άκαπνο περιβάλλον και με πλήρη συσκευασία.
Τιμή 1100 ευρώ
Marantz AV7704 Specs
Tuner
Audio
Video
Connectivity
General
Τιμή 1100 ευρώ
| Channels | 11.2 |
| Audio Formats | Dolby TrueHD, DTS HD Master Audio |
| Object-Based Audio Support | Dolby Atmos, DTS:X, Auro-3D |
| Supported File Formats | WMA (non-copyright protected), MP3, WAV, MPEG-4 AAC (non-copyright protected), FLAC, Apple Lossless, DSD |
| Digital-to-Analog Converter (DAC) | 32-bit AKM |
| Tuner | AM/FM |
| Reception Frequencies | AM: 520 to 1710 kHz FM: 87.5 to 107.9 MHz |
| Sensitivity | AM, Effective: 18 μV FM, Effective: 12 μV (12.8 dBf) FM, 50 dB, Mono: 2.8 μV (20.2 dBf) |
| Signal to Noise Ratio | FM, Mono: 70 dB (IHF-A weighted, Direct mode) FM, Stereo: 67 dB (IHF-A weighted, Direct mode) |
| Distortion | FM, Mono: 0.7% (1 kHz) FM, Stereo: 1% (1 kHz) |
| Input Sensitivity | Analog: 200 mV Phono Equalizer: 2.5 mV |
| Frequency Response | Analog: 10 Hz to 100 kHz, +1, -3 dB (Direct mode) |
| Signal to Noise Ratio | Analog: 105 dB (IHG-A weighted, Direct mode) D/A Output: 102 dB Phono Equalizer: 74 dB (A weighting, with 5 mV input) |
| Distortion | Analog: 0.005% (20 Hz to 20 kHz, Direct mode) Phono Equalizer: 0.03% (1 kHz, 3 V) |
| Rated Output | Unbalanced RCA Pre-Output: 1.2 V Balanced XLR Pre-Output: 2.4 V D/A Output: 2 V @ 0 dB playback |
| Total Harmonic Distortion (THD) | D/A Output: 0.008% (1 kHz, @ 0 dB) |
| Dynamic Range | D/A Output: 100 dB |
| RIAA Equalization Deviation | ±1 dB (20 Hz to 20 kHz) |
| Input/Output Level and Impedance | Composite, Component Y: 1 Vp-p, 75 Ohms Component PB/CB, PR/CR: 0.7 Vp-p, 75 Ohms |
| Frequency Response | Composite: 5 Hz to 10 MHz, 0, -3 dB Component: 5 Hz to 60 MHz, 0, -3 dB |
| Wi-Fi | Network Type: IEEE 802.11a/b/g/n Security: WEP 64-bit, WEP 128-bit; WPA/WPA2-PSK (AES); WPA/WPA2-PSK (TKIP) Frequency Range: 2.4, 5 GHz |
| Bluetooth | Version: 3.0 + EDR (Enhanced Data Rate) Transmission Power: Class 1 Range: Up to 98.4' (30 m) with line of sight Frequency Range: 2.4 GHz Modulation Scheme: FHSS (Frequency-Hopping Spread Spectrum) Supported Profiles: A2DP (Advanced Audio Distribution Profile) 1.2, AVRCP (Audio Video Remote Control Profile) 1.5 Corresponding Codec: SBC Transmission Range (A2DP): 20 Hz to 20 kHz |
| AirPlay | Yes |
| Audio Return Channel (ARC) | Yes |
| HDMI CEC | Yes |
| Inputs | 8 x HDMI (1 x front) 2 x digital coaxial 2 x optical TOSLINK 3 x component video 4 x composite video (1 x front) 7 x stereo RCA (1 x front, 1 x Phono) 1 x 7.1-channel RCA |
| Outputs | 3 x HDMI 1 x 1/4" (6.35 mm) headphone (front) 1 x component video 2 x composite video 1 x unbalanced 11.2-channel pre-out 1 x balanced 11.2-channel pre-out 1 x stereo RCA zone 2 1 x stereo RCA zone 3 |
| Other Ports | 1 x USB in(front) 1 x setup microphone in (front) 1 x RS-232C 1 x Ethernet LAN 1 x RCA remote control in 1 x RCA remote control out 1 x 1/8" (3.5 mm) IR flasher 2 x 1/8" (3.5 mm) DC 12 V, 150 mA out 1 x ground terminal 1 x FM antenna in 1 x AM antenna in 2 x Bluetooth/Wi-Fi antenna in 1 x AC power in |
| Power Requirements | 120 VAC, 60 Hz |
| Power Consumption | Active: 60 W Standby, Network Control and HDMI Pass Through Off: 0.2 W CEC Standby: 0.5 W |
| Dimensions | 17.38 x 7.38 x 16.25" (44 x 18.5 x 41.1 cm) with antennas down 17.38 x 9.75 x 16.25" (44 x 24.7 x 41.1 cm) with antennas up |
| Weight | 22.9 lb (10.5 kg) |
