Melody Valve Hi-Fi
Australian designed amplifiers
This Melbourne based company is renowned for its highly experienced research specialists heading its own research and development department.
Melody Valve Hi-Fi has qualified, industry based management responsible for the production plant meeting the needs of all modern music enthusiasts.
Through extensive research over many years, Melody Valve Hi-Fi has developed a series of high end valve amplifiers of the highest quailty, set at a price that is both competitive and affordable.
So far, the Melody valve amplifier series has overwhelmingly captured the imagination of valve music enthusiasts.
Melody products are registered and authenticated in Australia.
H88II
Vacuum Tube: KT88×2,6SN7×3,
Power Output: 50W
Frequency Response: 20Hz~30KHz
Output Impedance: 4Ω,8Ω
Input Sensitivity: 800mV
S/N:≥85dB T.H.D: 1%
AC Power: AC 220V±5% 50Hz~60Hz
Dimensions(mm): 285(W)×185(H)×275(D)
Weight: 18kg
Vacuum Tube: KT88×4,6SL7×2,6SN7×2 5687×2
Power Output: 50W+50W ClassAB1
Frequency Response: 20Hz~20KHz
Input Impedance: 250KΩ
Input Sensitivity: 380mV
S/N:≥90dB T.H.D: 1%
AC Power: 220V±5% 50Hz~60Hz
Dimensions(mm): 430(W)×185(H)×380(D)
Weight: 28kg
Περισσότερα:
http://www.melody.com.au/product.htm
Evasound
