Micro System with CD and top mount iPod dock RD-N1 JVC
Σε αψογη κατασταση,αγορασμενο πριν δυο χρονια για την μητερα μου αλλα δεν καταφερε ποτε να το δουλεψει,οποτε εμεινε να καθετε στο ραφι.
Τιμη 60 ευρω
Playable Media/Formats
CD Yes
CD-R/RW Yes/Yes
MP3 (CD-R/RW) Yes (with ID3 Tag)
WMA (CD-R/RW) Yes (with WMA Tag)
1-bit D/A Converter Yes
Number of Programs 32
Random Play Yes
Repeat Play Yes (1 Track/ All Tracks/ Group)
Tray Lock Yes
AMPLIFIER RD-N1
Power Output
At 10% THD (Full-Range) 3 watts per channel, min. RMS, driven into 3 ohms, at 1kHz, with no more than 10% total harmonic distortion
MP3 Text Display
ID3 Tag Yes
Sound Mode FLAT/ JAZZ/ ROCK/ POP/ CLASSIC
Hyper Bass Sound Yes
Connection for iPod(R) Yes (Direct Docking)
USB Host* [1] Yes
TUNER RD-N1
Band FM
Preset Stations 20 FM
Digital Tuner Yes
USB HOST RD-N1
Playable Formats MP3/WMA (with ID3/WMA Tag)
Repeat/ Random/ Program Play Yes (1 Track/ All Tracks/ Group) / Yes / Yes (32)
Power Supply Yes
CONNECTION FOR iPod(R) RD-N1
Direct Dock Yes
Power Supply Yes
Control Key Play, Pause, Forward, Reverse, Repeat, Select Track, Sleep Mode
INPUT/OUTPUT RD-N1
Analog Audio Input Yes (Front)
Headphone Out Yes (Front)
SPEAKERS RD-N1
Main L/R Speakers 3-9/16" (9cm), Cone
Type Full Range
Bass-Reflex Design Yes
GENERAL RD-N1
Back Illuminated LCD Yes (White)
Sleep Timer Yes
Remote Control Yes (Full Function)
Power Source
AC 120V, 60Hz
Dimensions (W x H x D)
inches 15-3/4 x 5-9/16 x 8-5/16
mm 400 x 141 x 211
Weight (Without Batteries)
lbs. 7.3
kg 3.3
wendigo
