Micromega M1 Range
M-One is not only an integrated amplifier, but a window into a unique musical experience …
It is often the most demanding constraints that inspire engineers and designers to strive for creative and innovative solutions. Our tailor made M-One integrated amplifiers are a perfect example (M.C.F.) !
No single audio product before the M-One delivers such a feature-packed and modern product that fits into such a small and elegant space – crafted from a single block of Aluminium.
Against all the odds, our engineers have managed to incorporate all the latest connections – Bluetooth aptX, LAN-Network 24bit /384kHz Asynchronous, SPDIF Coax-Opto-AES 24bit / 768kHz USB asynchronous passing DXD, DSD, DOP…, Phono MM / MC, Analog balanced and unbalanced inputs, and DSP with automatic room correction
(M.A.R.S). All in an amazingly compact module, whose cabinet is cut in the mass of a single block of aluminum.
It’s an absolute engineering miracle !
Available summer 2016
M.A.R.S is a ground-breaking electro-acoustic research program which has been developed by our engineers to integrate all the parameters of your
listening space with your M-One. Several options will be available and a
revolutionary “Binaural” system has been engineered to further enhance the performance of your headphones.
To enable a customer to integrate the M-One products into their home decor or indulge their own individual style, M-One products can be uniquely cosmetically customized in leather, carbon or aluminium by French craftsmen to provide an almost endless choice of finishes and colours.
“Everything is possible”
  • 1- Mic input
  • 2- Ground connection for Phono
  • 3 – MM/MCSwitch
  • 4 – Phono input
  • 5 – Analog RCA input
  • 6 – Analog Balanced input
  • 7 – Trigger In/Out
  • 8 – Digital COAX input
  • 9 – Digital Optical input
  • 10 – Digital AES-EBU input
  • 11 – Wi-Fi Antenna
  • 12 – RST (Reset)
  • 13 – Status LED
  • 14 – WPS (Wi-Fi Protected Setup)
  • 15 – USB 32-bit DSD
  • 16 – I2S1 connection
  • 17 – I2S2 connection
  • 18 – Bluetooth Antenna
  • 19 – LAN network connection
  • 20 – USB input for M-One software option
  • 21 – USB input for M-One software updates
  • 22 – Speaker outputs
  • 23 – Preamp outputs
  • 24 – SUB Out
  • 25 – Fuse
  • 26 – IEC Power input socket
http://micromega.com/en/products/m1-range/
Sugah
Ζαχαρούλης
Ελπίζω να παίζει σαν Devialet και να μην το τιμολογήσουν σαν Devialet, γιατί κατα τα άλλα δείχνει εξαιρετικό μηχανάκι
Λογικά,με το ρυθμό που εξελίσσεται η τεχνολογία,αναμένω να παίζει σίγουρα καλά.Τώρα για την τιμολόγησή του...αναμένουμε.Δε νομίζω πάντως πως θα είναι και οικονομικό,αφού μας έχουν μυριστεί πως σκάμε τα χιλιάρικα για ένα σωρό λογής λογής χαλιεντιές!
George Markop
