Mitsubishi HC5500 & Elite Cinema Screen
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
SPECIFICATIONS
Design: LCD Projector
Native Resolution: 1920 x 1080
Brightness: 1200 ANSI Lumens
Contrast Ratio: 14,000:1 (Full On/Off)
Dimensions: 4.9" H x 13.1" W x 13.9" D
Weight: 12.3 Pounds
MSRP: $1,995 (after $500 mail-in rebate)
Design: Manual Pull-up Projection Screen
Material: MaxWhite, 1.1 gain
Screen Size: 84" Diagonal
Dimensions: 80" H x 71.2" W
Weight: 22.3 Pounds
MSRP: $389.99 USA
The Mitsubishi HC5500 is another good, value-priced 1080p front projector. Compared to the Sanyo PLZ-2000, it has certain attributes that make it a more attractive option for those interested in a permanent installation, such as anamorphic lens compatibility and motorized zoom and focus. On the other hand, the Mitsubishi’s limited placement options mean that for consumers interested in maximum flexibility, they should carefully consider whether the HC5500 is appropriate given their room and screen size preferences.
http://www.hometheaterhifi.com/projector-reviews/projectors/affordable-projectors-for-non-dedicated-home-theater-rooms---mitsubishi-hc5500--elite-cinema-screen.html
proteusjohn
