Mitsubishi WD3300U Fixed Installation Projector
[imgl]http://www.projectorcentral.com/img.cfm?pid=4771[/imgl]The Mitsubishi WD3300U is a mid-sized, high-powered projector for large presentation environments. It is loaded with features, including interchangeable lenses, great placement flexibility and powered adjustments, a sealed color wheel, fantastic warranty, and more connections than you can shake a stick at. The WD3300U is flexible, capable, and easy to use. Street prices around $4500 make this one a good value.
Source: projectorcentral.com
Spiromag
