[imgl]http://www.projectorcentral.com/img.cfm?pid=6314[/imgl]The Mitsubishi WD380U-EST is highly capable. From its unique lensing to its robust connection panel, the projector seems to have an answer for everything. Its long life lamp is a boon for schools and businesses trying to save a few bucks, while its network capabilities are tailor-made for busy conference rooms. The image presets are sensible and useful and do not require a lot of adjustment. Fan noise is low, while the 10W speaker is loud and the new audio features work without a hitch. The focus adjustment is a little sticky, and the remote could be improved, but overall the WD380U-EST is a rock-solid projector that we have no problem giving our highest recommendation. If you need a big picture in a little room, this is your answer.
Source: projectorcentral.com
