Mitsubishi WD8200U -- Editor's Choice Award
[imgl]http://www.projectorcentral.com/img.cfm?pid=5767[/imgl]The WD8200U is a feature-rich, high-performance fixed-installation projector from Mitsubishi. It has all of the features one would expect from a big fixed-install projector, from interchangeable lenses to a rolling dust filter to an included cable cover. But it also includes some new features, such as side-changing lamps, 360-degree cooling, heat pipe technology, an interchangeable color wheel, and a perpetual filter that never needs to be replaced. The lamp relay mode never requires a shutdown during normal operation. Filter cleaning can be customized. The list goes on. The WD8200U is a projector that includes just about everything, and then includes the ability to customize just about everything. It is, in short, the large venue projector for all occasions and installations.
Source: projectorcentral.com
  • loggeo
simplygades
