Mitsubishi XD600U 3D Projector
[imgl]http://www.projectorcentral.com/img.cfm?pid=4942[/imgl]Mitsubishi's XD600U is a compact powerhouse of a projector. With a weight of less than eight pounds and 4500 ANSI lumens of brightness, it is a versatile, portable option for large-venue installation. Its 1.5:1 zoom lens makes it easy to install, and 3D capability goes a long way towards making it future-proof. Maintenance costs are kept low thanks to a filter-free design and long lamp life. Wired networking makes things simple for the folks in charge of maintenance, as well. All in all, the XD600U is a projector that is designed to deliver a great image for a reasonable price, both up-front and in the future. If you are looking for a versatile projector for a large-scale rollout, the XD600U may be just what you're looking for.
Source: projectorcentral.com
Spiromag
