MM de Capo BE Monitor speaker
Chameleon Audio
ex demo κομματι σε υπεραριστη κατασταση και με 5 χρονια εγγυηση .
Τιμη απο 4200e
μονο στα 2900e
Εαν καποιος θελει και τις Ρυθμιζομενες εργοστασιακες βασεις απο 850 e μονο 350e
The new MM de Capo BE simply is incomparable. This monitor is now even more refined than the award winning original model. At the heart of the MM de Capo BE is the hand built carbon fiber main driver. It is now even faster and better controlled.
The new high frequency unit is sonically more transparent and detailed than the original. It now has no ferro-fliuds and a much lower resonant frequency. It now integrates even better with the main driver.
The cabinet dimensions are unchanged. Critical bracing points have been optimized to achieve an even more silent cabinet and less interference with the drivers.
The recent updates to the MM de Capo BE include a new beryllium tweeter which extends to 40 Khz, Surreal Acoustic Len on the driver cone to stop air vortex distortions, and the Nextel matte coated cabinet which reduces diffraction effects and absorbs surface vibrations.
SPECIFICATIONS
Sensitivity 92 dB
Impedance 8 Ohms
Frequency Response 42Hz to 40KHz
Power Handling 150 Watts RMS
Phase Coherent
DIMENSIONS
Height 15" (38 cm)
Width 11" (28 cm)
Depth 13" (33 cm)
Weight 27 lbs (13 kg) each
REVIEWS
SOUNDSTAGE HI-FI ENJOY THE MUSIC
HOME THEATER REVIEW CANADA HI-FI
njpatilis
