Προφανώς Fender Custom Shop βασισμένο στο Precision Bass της Fender, κλασικό εμβληματικό sunburst χρώμα. Σε 1000 κομμάτια με τιμή $3,495.00
Specifications
Motor: 300 RPM AC Synchronous
Speeds: 33 1/3 RPM, 45.0 RPM
Platter: 6.8 lb Delrin (3,1 Kgr)
Wow & Flutter: 0.017% – 0.025%
Signal-To-Noise Ratio: 74dB
Power Supply Requirements: 120V 60Hz, 220-230V 50Hz, 100V 50Hz
Power Consumption: < 5W
Dimensions: 20.75″ x 6″ x 15.5″
Weight: 25.5 lbs. (11,5Kgr)
Tonearm:
Type: 10″ Straight Aluminum, Gimbaled Bearing
Overhang: 0.71″ (18mm)
Offset Angle: 22.8˚ (+/- 2˚ adjustable)
Cartridge Weight Range: 5g – 10g
mofi.com
Yγ.... μμμμ το ανεβασε ο κύριος spock στο analog news ήδη άρα ας διαγραφεί μην πιάνει χώρο.
Specifications
Tonearm:
MoFi Electronics - PrecisionDeck Fender Turntable
U.S.A.-Made Turntable Features Iconic Sunburst Finish, Sounds Incredible, and Is Limited to Just 1,000 Numbered Units Turntables will be offered to customers via email on the "Notify When Back In-Stock" list in order of request receipt. Please click the yellow "Email When In-Stock" button above...
