Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
To πιο πρόσφατο δημιούργημα της simaudio το moon orbiter ,universal player...
Χαρακτηριστικά...
Advanced switch mode power supply with additional analog filtering, 8 stages of voltage regulation (2 for analog video, 2 for analog audio, 2 for digital audio/video circuitry & 2 for the drive mechanism) and an integral shield to ensure no high frequency noise will interfere with audio and video signals · DVI-D output for progressive scan (480p) using SiI504 Video Scan Converter · Optional Serial Digital Interface (SDI) video output · S/PDIF (BNC & RCA), AES/EBU (XLR) and Optical (Toslink) digital audio outputs · Audiophile-grade 24-bit/192kHz digital-to-analog converters (3) with 8X oversampling digital filter for 2 & 6 channel analog audio output · 10-bit/54MHz oversampled video with active current-to-voltage converter · "Rack mount ready" faceplate with removeable aluminum cheeks to cover the holes when not in use · Front panel "VIDEO OFF" switch to disable all video circuitry, enhancing "audio only" sonic performance · Support for
both NTSC and PAL video formats · A complete array of various video output connections · Animated on-screen-display menus · SRS Labs TruSurroundä 3D surround DSP effects for optional analog audio outputs · Full function RS-232 port control for custom integration or automation · 1/8" IR Remote jack input for multi-room operation · "Parental Control" setting to allow authorized access to specific DVD-Video discs · Extremely rigid chassis construction to minimize the effects of external vibrations · Accurate matching of the high quality electronic components · Very short signal paths to maintain the integrity of audio and video information · Designed to be powered up at all times for optimal performance · Low operating temperature for a longer than normal life expectancy.
Και το Link για περισσότερες πληροφορίες
http://www.simaudio.com/moonorbiter.htm
