Περισσότερα:
http://www.musicalfidelity.com/mf/en/Products/A5/a5_cd
Specifications:DAC architecture 24 bit Delta-Sigma (Bitstream)
Dual differential
8x oversampling
Valve (tube) output stages
Disc mechanism Philips
Upsampling 192kHz
Frequency response 10Hz to 20kHz +0 / -0.2dB
Signal / noise ratio > 113dB 'A' weighted
Total harmonic distortion < 0.003% 10Hz to 20kHz
Total correlated jitter < 135 pS
Channel separation > 105dB 20Hz to 20kHz
Linearity < 0.1dB down to -96dB
Audio output at digital 0dB level 2.15VRMS at 1kHz nominal
Analog output 1 pair RCA connectors
Analog output impedance 47 Ohms
Digital outputs 1 optical (Toslink),
1 S/PDIF (RCA connector)
Power requirements 100 / 115 / 230V AC 50 / 60Hz (factory preset)
30 Watts
Dimensions (approximate) 436mm, 17.2 inches wide
125mm, 4.9 inches high including feet
387mm, 15.3 inches deep including rear terminals and on/off button
Weight 10.2kg, 22.5 lbs unit only, un-boxed
12.7kg, 28 lbs in shipping carton
Standard accessories Remote control handset (universal type), 2 batteries size LR03 or AAA, manganese alkaline type, IEC mains lead (10 Amp type)
