Musical Fidelity Encore 225
Ev 8848
Musical Fidelity Encore 225 streaming integrated amplifier σέ άριστη κατάσταση, είναι με 2 Tera bytes σκληρό δίσκο, μαζί το κουτί με όλα τα παρελκόμενα, η αγγελία ισχύει μέχρι τέλους του χρόνου.
Τιμή πώλησης 1800 ευρώ, για άμεση επικοινωνία τηλ 6974273622.
TECHNICAL SPECIFICATIONS
Type: Streaming, all-in-one ripping CD player/amplifier
Analogue Inputs: 3 × Line Level RCA 300mV nominal 2V typical up to 7V rms
Digital inputs: 2 × optical S/PDIF 24 bit inputs up to 192kHz, 2 × coax S/PDIF 24 bit inputs up to 192kHz, 1 × USB 3.0 type ‘A’ connector, 1 xUSB 3.0 type “B” connector (for future expansion), 3 × USB2.0 type ‘A’ connector (1 front, 2 rear), 10/100/1000 Base-T Ethernet connector
Outputs: 1× line level fixed 2.0V @ 0dBFS (300mV rms nominal, >6V rms max), 1× line level preamp variable outputs (>6V rms max) (Preamp gain, line input to preamp outputs is 4.5x (13dB) at maximum volume), Headphone output suitable for headphones impedance 8 ohms to ∞. (Headphone output features independent volume setting)
Digital precision: 1× optical S/PDIF 24-bit output up to 192kHz, 1× coax S/PDIF 24-bit output up to 192kHz
Speaker outputs: 1 pair 4mm banana plugs per channel
Power output: 225 Watts per channel into 8 Ohms
THD (+ noise): < 0.007 % typical 20Hz–20 kHz
Signal to Noise Ratio: >107dB ‘A’ – weighted
Frequency Response: +0, –0.1dB, 10Hz to 20 kHz
Internal storage: 2.5” 1 TB SATA II hard disk (included) or SSD (future upgradeable)
Dimensions W×H×D: 44 × 12.5 × 40cm
Weight: 18 kg
nikpapageo
