Musical Fidelity X-80.Απλα μια πετσοκομμενη εκδοση του Χ-150?
tyler durden
Μη ριβγιούερ
....η μια πραγματικα καλη αγορα?
[/img]
Features & Benefits
Uses same pcb as X-150. Has very similar sonic characteristics to X-150 with a little less power.
Upgradability. In UK only the X-80 can be upgraded to an X-150 at the retail price difference plus £50.
Features & Benefits
Output
Power 55 Watts one channel into 8 Ohms (17.4dBW)
85 Watts one channel into 4 Ohms
Voltage RMS 21 Volts 20Hz to 20kHz, one channel loaded
Voltage Peak 59 Volts
Peak-to-peak output current 28 Amps
Damping factor 77
Output devices per channel 2
Pre-output impedance 50 Ohms
Line inputs
Total harmonic distortion + noise < 0.02% 20Hz to 20kHz
Signal / noise ratio > 93dB 'A'-weighted
Input sensitivity for 55 Watts, 8 Ohms 175mV
Input impedance 220k Ohms
Overload margin 29dB
Channel separation > 55dB typical
Frequency response 20Hz to 20kHz, + 0, - 0.4dB
General
Input facilities 4 pairs line level RCA connectors
Output facilities 2 amplifier channels via 1 pair per channel binding posts.
1 pair RCA audio outputs controlled by the volume,
1 pair RCA tape record fixed line level output.
Power Requirement 100 / 115 / 230Volts AC 50 / 60Hz (factory pre-set),
190 Watts maximum into 8 Ohms, 15 Watts idle.
Dimensions 218mm, 8.6 inches wide
98mm, 3.8 inches high (including feet)
339mm, 13.4 inches deep (including knob and rear terminals)
Weight 6.5 kg, 14.3 lbs unit only, unboxed
8 kg, 17.7 lbs in shipping carton
Τ
ΤΑΣΟΣ ΑΝΤΩΝΑΡΑΚΟΣ
Οπως το ειπες,απλα δεν ερχεται στη χωρα μας.....δεν εχει και νοημα μαλλον
Θάνος Γαλάνης
