Nατα και η κυρια .....SONY !!!!!
vlasis
Φωτογράφος!
Sony’s AV products like BRAVIA flat screen TVs, VAIO PC and laptops can now provide high quality sound and better video using the newly launched high performance AV Cables. These cables support full 1080P HD signals and come in 1, 3 and 5 metre length. The connectors of the AV Cable are 24K gold plated to prevent them from corrosion.
These high grade cables give excellent signal transmission. The cables have an outer jacket that prevents them from heat and bending and improves sound quality. With OFC braided and OFC spiral wiring, aluminium tape and triple shielded core wire, the high performance shielding system reduces interference. The easy to install cable maintains a constant electrical current as it is made by 99.996% oxygen free copper (OFC) and hence the result is high quality audio and video signal transmission.
DAMBO
