Nad 302
Ενισχυτής Nad 302 σε άριστη εμφανισιακη και λειτουργική κατάσταση
Description
Because our engineers put sound quality first, the budget NAD 302 was voted European Amplifier of the Year 1993 - 94 and also a HiFi Choice ‘Best Buy’.
The 302 is modestly rated at 25 watts per channel into 8 ohms, but effortlessly handles peaks of 75 watts.
Tone Defeat allows you to switch out the tone control circuitry for a more direct signal path.
Important fine detailing like the low noise phono pre-amp, separate pre and power amplifier sections (for future upgrading) and heavy duty loudspeaker binding posts all add up to make a fine sounding, easy to use and hugely successful amplifier.
Specifications
Power output: 25 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.03%
Damping factor: 60
Input sensitivity: 2.7mV (MM), 165mV (line)
Signal to noise ratio: 77dB (MM), 90dB (line)
Dimensions: 420 x 108 x 320mm
Weight: 6kg
Year: 1993
τηλ 6956033668
τιμή 155€
Hdch
