Naim DVD5 : DVD player
Specifications
Media Supported
DVD-Video, DVD-Audio, DVD+/-R, DVD+/-RW, CD Audio, CD-RW and CD-R
Video Outputs
Digital Visual Interface (DVI) with HDCP copy protection
RGB/RGBHV (for non-macrovision encoded discs) via BNC, 75-Ohm
YPbPr via BNC, 75-Ohm
RGB interlaced (for non-macrovision encoded discs) via SCART, 75-Ohm
YPbPr interlaced via SCART, 75-Ohm
S-video via 4 pin DIN, 75-Ohm
Composite via SCART, 75-Ohm
Video Features
Faroudja DCDi de-interlacing technology
Automatic PAL or NTSC playback and conversion
Black-level setup for NTSC (0IRE or 7.5IRE)
Up to five different format simultaneous video outputs
16:9 and 4:3 aspect ratio support
Video zoom support
Picture adjustment including saturation, contrast and position
-60x -30x, -16x, -8x, -4x, -2x, 2x, 4x, 8x, 16x, 30x, 60x speeds
Full easy to navigate OSD with built in test screens for display calibration
Full +/- time delay lip sync
Forthcoming scaler upgrade card with custom resolutions including 720p and 1080p
Audio Output
Two digital coax and two digital optical
2 Volt RMS analogue stereo from 24bit, 192kHz re-clocked DACs via 5-pin DIN and stereo phono sockets
Up to 7.1 channel with multi-channel audio upgrade fitted, 24bit 96kHz via DIN sockets
Communications
Full integration with Naim AV2 processor including AV2 OSD
RS232 control for custom install and home automation
Power Supplies
Fully Linear, 20 independently regulated supplies with advanced ground
Mains supply
100 - 120VAC or 220 - 240VAC 50/60Hz, 50W
Dimensions
(H x W x D)
70 x 432 x 301mm
Finish
Black
koskef
