Nakamichi VU29 LCD
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
VU 29 features a state-of-the art TV grade LCD screen that provides a better dynamic response, viewing angle and contrast ratio.
The screen utilizes Ultra-High Aperture TFT (UHA TFT), LCD panel technology that delivers extremely wide viewing angles (170 degrees H/V & 170 degrees L/R - using SVA technology) and an exceptionally high contrast ratio of 600:1.
Additional enhancements such as DCDi (Direct Correlational Deinterlacing) provided by Emmy Award winning Faroudja technology to produce a smoother more natural image and Motion Adaptive Cross color suppression to remove "false color" artifacts produced by improper Y/C separation in low cost video decoders provide for a superior viewing experience.
29 inch high quality TFT LCD Panel
WXGA 1280 x 768 pixels resolution
Separate Digital Multimedia Module
View angle 170 degree horizontal and vertical
Photo Viewer
43-key IR/UHF remote control
Video and PC picture in picture
Digital 3D comb filter
Stereo Sound with SRS Focus and TruBASS
Multi broadcast standard sound processor
NICAM, BTSC, FM-FM, A2, AM (L&L)
Support V-chip and close caption of US system
Support Teletext for European system
With PC function
Long-life backlight
Specifications
LCD Display with Stand
LCD Panel
(based on panel spec, typical as below)
Display area 631.68 x 379.01 mm
Aspect ratio 16:9
View angle 170 degree (H and V)
Pixel Pitch 0.493 mm
Color 16.7 million colors
Contrast 600:1
Luminance 450 cd/m2 (typ)
Lamp life 50k hours
Response time < 25 ms
Audio Speaker
Audio output 10W max per channel
User Interface Power On/Off, IR/UHF Remote, Volume, Channel, Input Source
Input Connector
Display link Mini D-Sub x 2
Input Connector
RF input Multi-standard Tuner (Option)
S-video Mini DIN 4-Pin x 1
Video input RCA Jack x 2
Component Video RCA Jack x 1 set
Scart RGB with Audio x 1 (European version)
Audio input RCA Jack x 3
Digital /Analog PC DVI-I
Memory Card Compact Flash and Smart Media type (in-front)
Output Connector
Audio output RCA Jack x1 (R/L)
Display Link Mini D-Sub x 2
Power
Power supply 100-240 VAC 47-63Hz
Max power consumption < AC 210W
Mechanical Items
LCD Display unit with Stand 805(W) x 1300(H) x 380(D) mm
Digital Multimedia Module 430(W) x 98(H) x 320(D)mm
Unit Weight 44kg (14kg for wall mount version)
Wall mount /table and floor stand integrated
Accessories
Remote control, AC power cord, user manual, audio/video cable
Nikos88
