NEC 42XR3 Plasma TV
Κώστας Φ.
Plasma Display Specifications
Screen Size 42" diagonal
Screen Aspect 16:9
Contrast Ratio [not published]
Brightness [not published]
Pixel Pitch 0.897mm x 0.675mm
hSync 15.5-110.0 kHz
vSync 50-120 Hz
Color System NTSC, PAL, SECAM
Data Signals VGA: 640x480 @ 60,72,75,85,100, 120 Hz
SVGA: 800x600 @ 56, 60, 72,75,85,100,120 Hz
XGA: 1024x768 @ 60,70,75, 85, 100 Hz
SXGA: 1280x1024 @ 60, 75, 85, 100 Hz
UXGA: 1600x1200 @ 60, 65, 70, 75, 85 Hz
WideVGA: 848x480, 852 x 480 @ 60 Hz
WideXGA: 1360 x 765 @60 Hz, 1280 x 768 @ 60Hz
MacIntosh: 640x480, 832x624, 1024x768, 1152x870
TV Scan Lines 480p 480i, 525p, 525i, 540p, 625p, 625i, 720p,1035i, 1080i
Input Terminals
Composite Video 1 (RCA and BNC)
S-Video 1 (4-pin mini DIN)
Component Video 1 (RCA x 3)
RGB Component Video 1 (BNC x 5)
VGA RGB Signal 1 (15-pin mini d-Sub)
DVI Digital Input 1
Stereo Audio In 3 (RCA L/R)
Serial Control (RS232C) 1 (9-pin mini d-Sub)
Output Terminals
Plasma Monitor Accessories
Audio Amplifier 9W x 2
Speakers Optional
Mounting Options Optional Mount Required
Also Included:
AC Power Cord, User Manual, Remote Control, Batteries, Cable Clamps, HDMI to DVI adaptor
Dimensions and General Specs.
Power Supply 100-120V @ 50-60Hz
Power Consumption 300 Watts
Dimensions 40.1" x 24" x 3.5"
Weight 65.00 lbs.
FCC Class FCC Class B, Home Use
Key Features of the NEC 42XR3 42" Plasma Monitor
42" NEC Plasma TV, HDTV (1024 X 768) Resolution
Long lasting: up to 60,000 hour half life
Best in class image quality and accurate image reproduction
Includes a 3 year maufacturer's warranty!
AccuShield features prevent screen "burn in"
Split screen functionality: Control PIP size, location, and aspect ratio
Flexible Input Options including DVI, VGA, and Component Video
Gamma 12 Color Processing: Industry-leading 68.7 Billion Colors!
Stereo Sound: Built-in 18W stereo amplifier
Exceptionally quiet operation
Dimensions: 40.1" x 24" x 3.5"
Weight: 64.0 lbs.
Πηγή: plasmatvbuyingguide.com
Andreas79
