Neumann KH 420 & KH 310 D
m1ts0s
News poster
Press Release: Neumann is expanding the successful KH line with its first midfield monitor – the KH 420. The active 3-way system (10-inch/3-inch/1-inch) is ideal for larger 5.1 and 7.1 configurations and listening distances of up to 11 meters.
With a corner frequency of 52 Hz, the KH 120 nearfield monitor set new standards in its class for low frequency performance. Neumann engineers have succeeded in raising the bar with the KH 420 too. Its 26 Hz corner frequency is not only lower than other comparable midfield monitors; it is also a whole octave lower than the KH 120. Anyone requiring even lower bass reproduction for surround systems with a dedicated LFE channel can add the KH 870 woofer to extend the response down to 18 Hz.
Computer-optimized drivers, the Mathematically Modeled Dispersion Waveguide (MMD™), acoustical controls for matching the speakers to the listening room, a highly flexible input section, and a wide range of mounting hardware make the KH 420 a versatile monitoring tool for the audio professional. The KH 420 has been designed to provide optimum dispersion regardless of the orientation of the cabinet. This is possible thanks to the rotatable waveguide section which contains both the high frequency and midrange drivers.
An optional Digital Input Module (DIM 1) is available for the KH 420 which provides the monitor with digital AES3 and S/P-DIF inputs and a delay function. This feature, which is available on both the digital and analog inputs, may be used for audio/video lip synchronization and to compensate for non-equidistant speaker placement. Maximum delay time is 409.5 ms with a minimum resolution of 0.1 ms.
"The KH 420 delivers an accurate picture of the tonal nuances of the original recording," says Wolfgang Fraissinet, President of Neumann.Berlin. "In order to deliver a perfect stereo image, the KH 420 pushes the boundaries of what is possible in terms of linearity, performance and close production tolerances. It reflects the quality-driven approach that Neumann.Berlin has been committed to for many decades".
The KH 310 D nearfield monitor
One of the most compact 3-way monitors in its class, the KH 310 is the perfect choice for situations where space is limited. In addition to extra digital inputs, this brand new digital version, designated KH 310 D, comes with all the delay features of the DIM 1 module described above.
With the KH 120 D, the KH 310 D and the KH 420 with optional DIM 1 module, Neumann now offers monitors in three distinct size classes to support a completely digital workflow.
Pricing and availability
Both monitors will be available from the beginning of October 2014. The manufacturer’s suggested retail price for the KH 420 is € 3837,- (excl. VAT) and € 2229,- (excl. VAT) for the KH 310 D.
http://www.neumann-kh-line.com/neum...oring_studio-monitors_midfield-monitors_KH420
http://www.neumann-kh-line.com/neum...ing_studio-monitors_nearfield-monitors_KH310D
χμμμμ....... παρ ολο που στην σελιδα τους ολοι οι χωροι ειναι full Adam monitors
ακομη και αυτος στη φωτο, δεν αναφερουν τα Neumann.....:idk: ισως ειναι σε σταδιο αλλαγης .......
ωχ.....λες να δουμε κρεμασμενα ..B&W ?:gotcha:
alkapsal
