Neumann KH 80 DSP
m1ts0s
News poster
With the KH 80 DSP, Neumann.Berlin launches its first studio monitor with digital signal processing. “Our DSP engine is an in-house development that primarily takes a formerly unknown variable and makes it calculable: the room. Expect clear, high-precision sound wherever you are monitoring,” explains Wolfgang Fraissinet, President of Neumann.
Thanks to the upcoming “Neumann.Control” software, in the future the new KH 80 DSP two-way near-field studio monitor will be able to fully calibrate itself to the room. This can be performed either automatically (Precision Alignment), with some simple questions (Guided Alignment), or adjusted with complete flexibility using the built in 8-band fully parametric equalizer (Manual Alignment).
“In the KH series we have always been obsessed with the details when it comes to the calculation and modeling of the drivers, waveguide and cabinet,” emphasizes Fraissinet. The result is a frequency response with such neutrality that it defines a whole new reference class – and at a price that was previously unthinkable for a Neumann Studio Monitor. Using mathematical models, the two drivers were calculated to a degree of depth, “which is unusual even for our industry,” explains Fraissinet. Nonlinear distortion is thus minimized from the very beginning. The MMD™ Waveguide (Mathematically Modelled Dispersion™) optimizes the frequency response on- and off-axis, and enables more movement within the listening area and more consistency even in the most varied acoustic environments.
The KH 80 DSP is designed as an ideal monitor solution for recording, mixing and mastering in project, music, broadcasting and post-production studios.
Every mechanical and electronic element – from the driver to the amplification – is handpicked and harmonized in accordance with Neumann standards. The DSP engine also ensures a linear frequency response with a FIR filter. This makes sure that in every environment all frequencies are precisely timed.
The KH 80 DSP will be available from February 2017.
Neumann.Control will be available from Q2 2017.
http://www.neumann-kh-line.com/neum...udio-monitors_nearfield-monitors_KH80_DSP_A_G
Άμα το βγάζαν σε τρέντι κόκκινο - μπλε - κίτρινο - λαχανί φινίρισμα ,με τιμή 100 - 150 ευρώ παραπάνω θα έκανε θραύση... Και λευκό...
deleted user 10898
Δυστυχώς μεχρι 24/48 το Dac του :(
Δεν έχει ψηφιακή είσοδο όποτε δεν σε νοιάζει τι Dac έχει...
τα 24/48 αρκούν για ada μετατροπή και εφαρμογή φίλτρων ψηφιακά χωρίς παράπλευρες απώλειες...
Ειχα την εντύπωση πως ειχε ψηφιακή είσοδο...εισαι σίγουρος;
m1ts0s
News poster
Neumann.Control enables you to Setup, Align and Operate your Neumann DSP system. It contains a demo modus so you can explore the app even you do not own Neumann DSP monitors yet.
Via standard IP networking, Neumann.Control gives full access to all the functions of the KH 80 DSP Studio Monitor not already available via the back panel. You can setup a system consisting of 1 to 9 loudspeakers and align it for a good in-room sound, and then operate it centrally.
The key features of Neumann.Control are:
Setup:
• 1, 2, 4, 5, 7 and 9 loudspeakers
• Identify loudspeakers on the network that are in the room
• Assign the identified loudspeakers to positions in the room
Align:
• Guided Alignment – a set of simple questions resulting a well-balanced sound. The Guided Alignment is a process where you are asked very simple questions about the room and the loudspeaker position, and then the app adjusts the response of each loudspeaker accordingly
• Manual Alignment – an 8-band fully parametric equalizer for expert users. In Manual Alignment expert users have complete freedom to adjust an 8-band parametric equalizer, levels and delays in each loudspeaker as they wish. Manual Alignment can also be used to edit Guided Alignments in a more detailed way.
Operate:
• System and alignment selection
• Volume control, preset levels, dim, mute all
• Groups, solos, mutes
• Other system settings such as delay, standby level and logo brightness
https://itunes.apple.com/us/app/neumann-control/id1394556417?mt=8
leftos
